Old Mar 30, 2016, 03:33 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Transmission Guides
Print Wikipost
transmission problem -3.4, Tacoma, auto, 4x4
Old May 20, 2010 | 08:29 PM
utjoe09z's Avatar
So a few hours ago I went mudding. after getting stuck I rocked it a couple times (not very hard at all), then all of a sudden after putting it in drive the RPM's went flying up and the tires did nothing. Its stuck in neutral and no matter what I shift to I still got nothing. I also tried shifting through all the 4x4 ranges and all that good stuff. My reverse lights come on when in reverse so its shifting correctly just no communication to the tranny. Have no idea where to start please help!
-Joe
(3.4, Tacoma, auto, 4x4)
Old May 21, 2010 | 04:29 AM
gdutch's Avatar
Check your ATF level. Any check engine lights come on? If so, could be a solenoid in your tranny.
Old May 21, 2010 | 05:14 AM
utjoe09z's Avatar
I checked the level, it was fine. And no check engine light =(
Old May 21, 2010 | 05:28 AM
kball's Avatar
Maybe while you were frame deep in goo and rockin back and forth something got pulled out like a sensor wire? Or maybe you got some goo in the wiring and it's shorting something out.
Old May 21, 2010 | 06:08 AM
mt_goat's Avatar
I've always heard rocking an auto tranny is hard on it, but I thought it was because over overheating. I guess the sudden shifting back and forth could also be hard on the pistons and valves in the valve body. Might start by checking the shift linkage under the truck (I think the reverse lights work off a switch under the shifter so the linkage could have slipped out of adjustment or come loose and they would still light up). If that's all fine, I might pull the VB and send it off to IPT for testing as that is easier that pulling the whole tranny. I guess another possibility is the torque converter, but you'd have to pull the tranny to replace that.
Good luck.
Old May 21, 2010 | 06:45 AM
utjoe09z's Avatar
okay thanks a lot for the advise!
Old Aug 19, 2011 | 04:45 PM
f.kigo's Avatar
Hello , Need some help please , i own a 1996 3.4 AT tacoma ,mi problem is specially when the gearbox and engine are cool , i put it in gear and fill the vehicle is kind of locked is a really scarry sensation sometimes i have tu accelerate a bit and "unlocks" but does not sound nice at all , ive got my rear diff locked , this just heppens sometimes and specially when engine still not hot enough. gears go very well when driving and have no other problems. but im really concerned about this issue.
thanks
Old Aug 19, 2011 | 05:16 PM
ZUK's Avatar
ZUK
thanks
Too high of an idle will cause the auto to grab alot and result in you using alot of brake pedal. Is the engine totally stock? what are the rpm's when this happens?
Old Aug 19, 2011 | 11:10 PM
f.kigo's Avatar
the engine is totally stock , my upgrades are suspension (front camburg racing full kit ans reare koni shocks) and some cosmetic upgrades as bushwaker fenders bull bars etc, nothing mechanic, mi problem happens when im stoped and starting to move not when im driving.
thanks
Jun 1, 2021 01:51 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Cplmike
Jul 8, 2015 08:47 PM
Jnkml
Jul 6, 2015 01:20 PM
