cylinder two missin
Old Jun 25, 2010 | 11:40 AM
billkmiami's Avatar
cylinder two missin
my 2000 taco 2.7 4 banger's cyclinder two is missing- threw a P0302 code- what do you think is burnt? Spark plug and wire seem fine??
thanks
Old Jun 25, 2010 | 11:58 AM
snobdds's Avatar
How do you know your spark plug and wires look fine? Have you pulled your plugs and looked at them? How many miles are on the wires? Have you check the resistance on the wires?
You need to eliminate the simple stuff before you can go to other items
Old Jun 25, 2010 | 12:02 PM
billkmiami's Avatar
how do i check resistance on the wire in question? I pulled the spark plug and it looked fine- can i trade coil packs? (switch them?)
Old Jun 25, 2010 | 12:13 PM
snobdds's Avatar
I forgot the 2.7 has coil packs - my bad. You will have to search for the FSM on here for your specific year and it will tell you how to check the resistance on the coil packs with an ohm meter.
It will also give you some trouble shooting tips for the code your getting.
Old Jun 25, 2010 | 02:18 PM
billkmiami's Avatar
just replaced all four spark plugs and installed new blue silicone ngk wires and it runs perfect! the blue wires look good under the hood!
4.34runner88
Feb 7, 2016 02:24 AM
Obmi
Nov 24, 2015 11:37 AM
Obmi
Oct 30, 2015 04:27 PM
eggens
Oct 27, 2015 03:14 PM
Squigglez
Sep 4, 2015 07:33 AM
