Having a problem understanding service manual gear lube spec.
Old May 31, 2010 | 10:22 AM
sharrack's Avatar
99 runner 4wd front diff fluid.
API - GL-5 SAE 90w
Wth A.D.D
75W90
Install under cover
What does A.D.D. mean ?
What if I can't find GL-5?
I'm replacing the CV shaft seal on the pass side and the fluid leaking out is pretty nasty so I figured I drain and fill.
Thanks Guys, Kenny S>
Old May 31, 2010 | 11:31 AM
DeathCougar's Avatar
ADD is Automatic Disconnecting Differential.
If you read your owners manual, it will tell you.
GL-5 is merely a spec rating for gear oil. Its listed on the back of the bottle, and almost every bottle of standard gear oil out there is GL5 spec.
Old May 31, 2010 | 11:51 AM
sharrack's Avatar
So I'm assuming that without manual hubs, I have automatic disconnect.
and I'll be going with the 75W90.
Thanks, Kenny S
bigjstang
Jun 2, 2025 03:56 PM
mskalmus
May 28, 2017 07:51 AM
Yota.Jay
Jul 23, 2015 08:08 PM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
