AT Fluid Leak?
Old Jun 14, 2010 | 04:32 AM
vtruong1's Avatar
AT Fluid Leak?
Hey guys,
I noticed a leak this past weekend and it looks like AT Fluid (Reddish). I flushed the tranny about 1 year ago and applied The Right Stuff for the gasket and hasnt been an issue.
I tried to narrow down the source of the leak, it doesnt look like its coming from the gasket on the tranmission pan or tranmission pan bolt for sure. But it looks like its coming from the front of the pan where it meets the engine?
Any ideas?
Old Jun 14, 2010 | 05:05 AM
gdutch's Avatar
Toyota uses red coolant too, have you checked that?
Old Jun 14, 2010 | 07:28 AM
vtruong1's Avatar
Thanks for reply, coolant is fine. Its definatly AT fluid.
Old Jun 15, 2010 | 05:21 AM
gdutch's Avatar
If it's where the engine meets the tranny that'd be the torque converter. I'm sure there's some sort of gasket situation up there. Need some more knowledgeable peeps to jump in here.
Old Jun 15, 2010 | 10:21 AM
vtruong1's Avatar
OK,
I think I found the source of the leak. HELP!
Other pics here: http://picasaweb.google.com/vytruong/4runner#
I cleaned up the oil and let the car sit. Noticed oil build up here. I made sure it wasnt just a collection point so I cleaned up all around and it looks like its leaking from this little point in the bell. Once I started the car, it seemed to make the leak quicker. It doesnt look like an easy fix at all..any ideas? Is there a gasket between the bell and the metel plate that screwed into it?
Old Jun 15, 2010 | 10:26 AM
PismoJoe's Avatar
No, there's no gasket. You can get a way better idea if you take off that "peek plate"
That bottom cover that you have pictured above can be easily removed (4 bolts IIRC)
Look in there and see if its dry. Its either the input shaft seal or something's up with your torque converter
Definitely need to drop the tranny if its one of those though
Old Jun 15, 2010 | 02:14 PM
vtruong1's Avatar
Anyone know what causes ATF to get behind this plate?
Old Jun 15, 2010 | 02:32 PM
PismoJoe's Avatar
Did you read my post? I just told you
Old Jun 15, 2010 | 02:58 PM
vtruong1's Avatar
Pismo,
Thanks for the reply, I was just wondering if anyone else had experianced the same thing so I could narrow down the exact issue.
Old Jun 15, 2010 | 03:50 PM
PismoJoe's Avatar
I personally have had this problem if it makes you feel better lol but heres a pic of your trans. The only 2 possibilities is the input shaft seal & front retainer gasket, or you're torque converter (unlikely but possible)
Old Jun 15, 2010 | 03:58 PM
vtruong1's Avatar
Ouch...
This sucks..looks like I gotta drop the trans. Wonder how much a shop would charge for this.
Old Jun 15, 2010 | 04:00 PM
PismoJoe's Avatar
Wayyyy too much lol
Did you take off that peek plate? It will give you a good idea if its leaking like a siv or just a drop here and there.
Old Jun 15, 2010 | 04:06 PM
vtruong1's Avatar
I didnt have a chance to take of the plate yet...but the leak has gotten worse the past few days
Old Jun 15, 2010 | 04:09 PM
ISFast's Avatar
Very good info i've got the same problem! Looks like i'll be taking the plate off tomorrow!
Old Jun 15, 2010 | 04:12 PM
vtruong1's Avatar
ISFast,
Sucks to hear you are in the same boat as me....let me know what you see.
Thanks
Old Jun 15, 2010 | 04:14 PM
PismoJoe's Avatar
Good luck guys!
Old Jun 15, 2010 | 04:15 PM
ISFast's Avatar
Will do but got to figure out the A/C first it just started blowing fuses. Will look the end of the week when i but my tranny cooler in.
Old Jun 20, 2010 | 05:03 PM
vtruong1's Avatar
ISFast,
Wondering if you got to investigate your leak at all. Seems like on short drives, I am ok but once I go 10 plus miles it starts to leak on me.
he's gone
7
Dec 3, 2019 07:08 AM
jasonty
41
Dec 23, 2018 01:00 PM
gmonnie123
Jul 26, 2015 02:44 PM
the1998sr5
Jul 16, 2015 06:20 AM
Rkellerman
Jul 12, 2015 08:42 AM
