rs3200 security system unistall
Old Jul 1, 2010 | 09:38 AM
mkk572ny's Avatar
Recently purchased a used 2000 4runner ltd and although i love it i absolutely hate the rs3200 security system the previous owner had installed extra when he originally bought the car. I was wondering if there was any way uninstalling this system without messing up the car. thanks...
Old Jul 1, 2010 | 09:42 AM
RMA's Avatar
RMA
are you sure this is your truck and not some ones elses ..
Old Jul 1, 2010 | 09:56 AM
mkk572ny's Avatar
lol yah. i really dont like how the horn honks when you lock/unlock and although it has some neat features i find that in the area i live are somewhat unnecessary. will a toyota shop do it and not charge an outrageous amount or is there a way where i can do it myself?
Old Jul 1, 2010 | 10:10 AM
kball's Avatar
Unplug your horns and you're good to go. I can't remember the last time I honked my horn at someone...
Old Jul 1, 2010 | 10:13 AM
mkk572ny's Avatar
yah but i still want to have the ability to honk my horn
Old Jul 1, 2010 | 11:14 AM
Gerdo's Avatar
I'm not sure how to un-install it but if you do get it uninstalled let me know, I may want to buy it!
Old Jul 1, 2010 | 11:26 AM
spokane.yota.man's Avatar
my 98 4R ltd had the factory alarm in it when i purchased it used. it didn't work so i just unhooked it by taking the control unit out. its a black box located under the driver seat. i don't remember if their were harnesses and that though. i had an aftermarket alarm installed and everything works fine.
Old Jul 1, 2010 | 11:54 AM
Nuthuts96's Avatar
From: Shelburne, VT previous: Everett, WA; Bellingham, WA
you can program the alarm to be silent when operating the lock/unlock.... it's how mine is setup.
here's an owner's manual with a simple google search:
http://www.empirepao.com/tsb/T-AI-0617-W.pdf
Old Jul 1, 2010 | 08:05 PM
tunnelmotor99's Avatar
Mine doesn't do the horn, it has the electronic "beep beep" which works sporadically. Its either a normal beep, a sick beep or nothing. Also I wish the remote worked more than 5 feet away. It has a new batt, I think it's just old...
Old Jul 2, 2010 | 12:01 AM
rjaudi's Avatar
Is it the rs3000 or rs3200? I know my 4runner has the rs3000, but its a 97. If you can verify which one I will try to help.
Tunnelmotor99, you just need a new piezo chirper. Any universal one should work.
Old Jul 2, 2010 | 06:09 AM
mkk572ny's Avatar
rjaudi- i believe its a rs3200 ill check ltr and get back to you
Old Jul 3, 2010 | 07:50 PM
mkk572ny's Avatar
Rs3200
Old Jul 4, 2010 | 08:53 AM
rjaudi's Avatar
Is the horn actually making the noise when you lock the car or is the car making a chirp noise? Are you looking to disable that noise or do you want to totally remove the system?
Old Jul 4, 2010 | 10:13 AM
mkk572ny's Avatar
Yes the horn honks when i lock/unlock (along with chirp). At the very least i want the horn disabled for lock/unlock but if possible i wuld disable the entire system.
Old Jul 5, 2010 | 12:31 PM
rjaudi's Avatar
You actully have the RS3200 plus. This was a add on for the factory keyless entry that came standard on the limiteds. I found this install guide for a 2003 tacoma installing rs3200 plus. If these connectors are there it should be a simple unplugging will do the trick.
http://www.parksoffroad.com/tacomamo...rs3200plus.pdf
Here is a guide for a RS3200 install on a tacoma:
http://www.parksoffroad.com/tacomamo...stallation.pdf
See if these work it shouldn't take long to get the plastic trim pieces off.
Old Jul 5, 2010 | 07:40 PM
mkk572ny's Avatar
thanks i will try it and let you know
Old Jul 8, 2010 | 07:29 PM
skjos's Avatar
Available for a limited time only, the 2000-2002 4Runner RS3200 Plus installation instructions:
http://home.centurytel.net/stevenjackie/RS3200Plus/
Scanning that sucked, if I'm ever in Jersey you owe me a beer.
Old Jul 8, 2010 | 08:53 PM
rjaudi's Avatar
That helps out alot. I was worried that the Tacoma rs3200 plus didnt have a glass breakage sensor shown. Now you can remove it and sell it to someone if you want.
Old Jul 9, 2010 | 04:42 AM
mkk572ny's Avatar
haha thanks both to both of you guys. im trying it ethier today or tomorrow.
Old Jul 12, 2010 | 06:24 AM
mkk572ny's Avatar
didnt get a chance to try it over the weekend (family emergency). just wanted to check that if i did unistall it, it wouldnt mess up the car like not being able to start it, lock/unlock, etc?
