rs3200 security system unistall
Recently purchased a used 2000 4runner ltd and although i love it i absolutely hate the rs3200 security system the previous owner had installed extra when he originally bought the car. I was wondering if there was any way uninstalling this system without messing up the car. thanks...
lol yah. i really dont like how the horn honks when you lock/unlock and although it has some neat features i find that in the area i live are somewhat unnecessary. will a toyota shop do it and not charge an outrageous amount or is there a way where i can do it myself?
my 98 4R ltd had the factory alarm in it when i purchased it used. it didn't work so i just unhooked it by taking the control unit out. its a black box located under the driver seat. i don't remember if their were harnesses and that though. i had an aftermarket alarm installed and everything works fine.
From: Shelburne, VT previous: Everett, WA; Bellingham, WA
you can program the alarm to be silent when operating the lock/unlock.... it's how mine is setup.
here's an owner's manual with a simple google search:
http://www.empirepao.com/tsb/T-AI-0617-W.pdf
Mine doesn't do the horn, it has the electronic "beep beep" which works sporadically. Its either a normal beep, a sick beep or nothing. Also I wish the remote worked more than 5 feet away. It has a new batt, I think it's just old...
Is it the rs3000 or rs3200? I know my 4runner has the rs3000, but its a 97. If you can verify which one I will try to help.
Tunnelmotor99, you just need a new piezo chirper. Any universal one should work.
You actully have the RS3200 plus. This was a add on for the factory keyless entry that came standard on the limiteds. I found this install guide for a 2003 tacoma installing rs3200 plus. If these connectors are there it should be a simple unplugging will do the trick.
http://www.parksoffroad.com/tacomamo...rs3200plus.pdf
Here is a guide for a RS3200 install on a tacoma:
http://www.parksoffroad.com/tacomamo...stallation.pdf
See if these work it shouldn't take long to get the plastic trim pieces off.
Available for a limited time only, the 2000-2002 4Runner RS3200 Plus installation instructions:
http://home.centurytel.net/stevenjackie/RS3200Plus/
Scanning that sucked, if I'm ever in Jersey you owe me a beer.
didnt get a chance to try it over the weekend (family emergency). just wanted to check that if i did unistall it, it wouldnt mess up the car like not being able to start it, lock/unlock, etc?
