98 tacoma wont go into 1st and 2nd sometimes
Old 05-22-2010, 01:34 PM
coke's Avatar
i am having a shifting problem, its hard to put in 1st and 2nd gear sometimes, but i never forced it in, its like something is blocking , is this a comment problem ? could it be the gear or the shifter , or just the bushings?
thanks guys
Old 05-22-2010, 01:43 PM
scuba's Avatar
Could be the clutch, low fluid, bad slave or master cylinder.. A few different things.
Is there brake fluid in the resivior?
Old 05-22-2010, 05:47 PM
coke's Avatar
i went out and drove it some more, it seems like there is a lock , if i do over 20mph it wont let me down shift to 2nd or 1st, but as soon as the needle drops below 20mph i can put it in 2nd but not 1st, it does this everytime, seems there is like a lock or something, i have a 2.4 5speed 98
i looked there is fluid in the resivior
Old 05-22-2010, 05:53 PM
PismoJoe's Avatar
Don't try to downshift into first going 20 mph, that will cause your syncro to get messed up.
Take scubas advice and check those things out, also check tranny fluid level and see if the fluid looks really dirty or something.
Old 05-22-2010, 06:23 PM
coke's Avatar
i just took it for a ride , my neighbor has the same truck, she rolled with me , i was able to put it in 2nd , but i have to use a lil muscle, i never drove a truck before maybe this is the way it should be , she said that this truck is diff from my honda, honda shifts so much smoother. i will check on those things tomorrow thanks you guys
i appreciate all your help!
Old 05-22-2010, 06:33 PM
Elton's Avatar
how many miles ?
Old 05-22-2010, 06:36 PM
coke's Avatar
128k on it running like new
Old 05-22-2010, 06:40 PM
Elton's Avatar
has the tranny fluid ever been changed ?
Old 05-22-2010, 07:02 PM
coke's Avatar
how can you check on the level ? is there a dip stick? or i have to take off the top drain plug like my integra
Old 05-22-2010, 09:58 PM
scuba's Avatar
Make sure the GEAR OIL is warm before you say it just shifts rough.
To check the level of the GEAR OIL park the truck on level ground and climb underneath. On the drivers side of the trans you will see a 24MM bolt, pull that and stick your pinky in it. If you have fluid within 5MM of the top you are fine.
Change the gear oil before coming to conclusions.
Your W59 will work okay with Mobile 1 75W-90 GL5, but the w59s are kind of picky and like the GL4 you can get at the dealer..
In case you needed it, here's your trucks FSM
http://www.ncttora.com/FSM/2003/index.html
Well, its for an 03, but mostly all the mechanical junk is the same.
Team420
12-30-2015 01:31 PM
izzmee
08-17-2015 10:20 AM
HollieJayyy
08-09-2015 07:59 AM
vanion2
07-29-2015 06:17 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
Quick Reply: 98 tacoma wont go into 1st and 2nd sometimes
