04 taco clutch adjustment
Old Jun 18, 2010 | 12:25 PM
typhoon55's Avatar
o4 taco with very short clutch throw
no problem engaging or disengaging but seems to be getting shorter
is there any adjustment on pedal or is this a sign of clutch on its way out?
Old Jun 18, 2010 | 02:35 PM
cws9685's Avatar
u can adjust your pedal if you look under your dash at your clutch pedal you will see a rod at the end of it with a lock nut losen it an turn the rod till you have about a 1/4 in of play in the pedal but it sounds like your clutch is on its way out
Old Jun 18, 2010 | 03:06 PM
PismoJoe's Avatar
There's really not too much adjustment in pedal play with our trucks. You can mess with the input shaft rod a bit, but that's about it. Just make sure that your pedal has a proper freeplay so its not dragging if you do mess with it.
Check the fluid level in the MC, just to rule out the hydraulic system as an issue. Other than that, your pressure plate could be wearing out causing it to lose some of its spring
Old Jun 25, 2010 | 07:16 AM
typhoon55's Avatar
what is the spec on distance from carpet to clutch engaging?
what is a ball park $$ on a clutch job?
Old Jun 25, 2010 | 08:56 AM
scuba's Avatar
Did you check the FSM for your first question?
http://www.ncttora.com/FSM/2003/index.html
Second. I'd say 4-600 plus parts.
Old Jun 25, 2010 | 09:22 AM
typhoon55's Avatar
is that clutch release point from full pedal stroke?
Old Jun 25, 2010 | 10:40 AM
typhoon55's Avatar
I see spec on the pedal in manual except the distance from floor to clutch engaging
Old Jul 12, 2010 | 08:38 AM
Kusotare's Avatar
The stealer near me says 6.7 hours labor for the clutch job on my '00 Taco (at $100 per hour) plus parts, which are normally around $350. I just spent Friday and Saturday doing mine. It's a huge PITA but worth the $700 saving in labor to me. Unfortunately my tranny is in need of a rebuild or replacement so I get to do it again. YAHOO!!
akamon808
3.4 Swaps
Dec 16, 2015 08:45 PM
rodskwad
Aug 12, 2015 02:33 AM
rap2me
Aug 11, 2015 05:03 PM
Crgrey42
Aug 10, 2015 04:23 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
