Power inverter wiring
Old Jun 17, 2010 | 03:57 PM
jonb's Avatar
Hello,
2000 4runner and just purchased small 200w/400w power inverter that I want to install under the passenger seat. Currently there is an old amp under the seat with 10g wire and a 40A fuse connected to the battery.
Can I just remove the old amp and install the new inverter or do I need to change either the wiring or the fuse size?
thanks for any help.
Jon
Old Jun 18, 2010 | 04:59 PM
98SR54RUNNER's Avatar
I wouldn't use old wiring unless by old you mean that you installed it not too long ago.
But, regardless, you shouldn't have any problem connecting your inverter to the battery via that power cable and grounding it. That fuse is plenty for your inverter and that gauge cable should be fine also. I've had a 750w inverter installed in the same wiring configuration for a while. My inverter has a power switch on it though so my inverter doesn't kill my battery, you might want to look into that.
Old Jun 18, 2010 | 06:42 PM
BajaRunner's Avatar
Should be good for a direct swap!
Sleaker
Aug 26, 2020 06:03 AM
keithporter83
Jul 24, 2015 07:37 AM
luckypig44
Jul 19, 2015 11:25 AM
Johntom240
7
Jul 13, 2015 12:18 AM
nick b
Jul 11, 2015 04:38 AM
