5vzfe Knock sensor wiring?
Old Jun 10, 2010 | 03:37 PM
xcmountain80's Avatar
Houston we have a problem, my recent motor swap went perfect (minor head scratching). All was installed when the unimaginable happened. The motor was running but seemed fully retarded, multiple codes were tripped the CEL. The problem was the knock sensor wire connector, on the harness side a number 11245 and on the knock sensor side 11166. I was unable to find anything in reference to either of these numbers and no wires or harnesses available. It’s a single pull wire but other than that I have nothing. Any help would be greatly appreciated as I’m dead in the water w/o this.
Aaron
Old Jun 10, 2010 | 03:59 PM
vital22re's Avatar
totally a bro
so is the knock sensor bad? Those wires are generally shielded.
Old Jun 10, 2010 | 04:58 PM
Knock sensor is good, connector is toast (brittle from 250k miles of heat) I founf the connector 90980-11166 and a picture on ih8mud if you search that number here http://www.ih8mud.com/tech/pdf/WireH...l/femalewa.pdf The mech. will call Toyota tomorrow and see what can be ordered. I'm fairly certain the wire portion can be ordered, though no confirmation yet.
A
montanatruck
Feb 26, 2017 07:07 AM
nonstop
Jul 24, 2015 06:29 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
88yodabasket
Jul 13, 2015 01:32 PM
smiley52
Jul 11, 2015 05:16 AM
