alignment specs 1997 surf
Old Jun 18, 2010 | 10:26 PM
hqgrundling's Avatar
Can someone please help me with wheel alignment specs for standard 1997 Toyota Surf (4Runner) 3RZ-FE
Old Jun 19, 2010 | 07:22 AM
DailyDrive's Avatar
It's really simple. Everything should be 0 degrees.
Old Jun 19, 2010 | 07:48 AM
mt_goat's Avatar
Yeah I like to shoot for zero (except for caster which I shoot for as positive as possible). There is a lot of tolerance in the factory specs (too much really). You can get camber within factory specs and see the wheel lean with your eye balls. You really don't need a fancy 3D alignment machine to set the camber to spec. Toe you can also do yourself with some basic measuring tools. Caster I just go for as positive as I can and have both sides close to the same (cross caster) and still get the camber I want.
Lots of DIY info if you google "DIY wheel alignment"
ladybugRC
458
Aug 21, 2020 10:41 AM
83yotastockR
11
Nov 10, 2015 06:54 AM
Dale Johnston
11
Oct 31, 2015 10:22 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
voiddweller
Sep 28, 2015 11:21 PM
