Long granny 1-2 shift, wut's up with that?
Old Mar 30, 2011 | 06:20 AM
Bawlzdeep's Avatar
All other shifts are as crisp as I would expect from a stock valve body but the 1-2 shift is a killer. Feel like I'm driving my Dad's Cadillac! Is this a common problem with these transmissions? Does it under normal and WOT. Seems like the valve body could use some attention. I can't find any shift kit's for this trans. Any known fixes or good kits? Fluid is less than 6mo old along with filter. I know my way around a trans so please, don't spare the technical jargon/assistance. Thanks
Old Mar 30, 2011 | 06:30 AM
badattitude's Avatar
Check the fluid level when Hot, these trans are sensitive to the fluid level. adding or removing a few ounces can make a differance. good luck
also check IPT for a valve body upgrade.
http://www.importperformancetrans.com/toyotaindex.shtml
80Truck
Oct 12, 2025 07:25 PM
jashoeuh
Nov 18, 2024 08:08 AM
Liadrin
Apr 25, 2022 02:54 PM
Liadrin
Sep 1, 2015 06:44 AM
crashburnoveride
Jul 10, 2015 06:39 AM
