HELP!!! need a 2.7 question answered fast!!
Old Mar 25, 2011 | 10:12 AM
99 sas runner's Avatar
i have a 99 taco non distributor 2.7 and i found a replacement motor for 500 but it has the distributor... will the older 2.7 even work? thanks in advanced.
dylan
Old Mar 25, 2011 | 11:46 AM
also whats the best head gasket for the 2.7
Old Mar 25, 2011 | 12:00 PM
blake.nemitz's Avatar
not sure on the block working but i would use toyota head gasket and maybe check to see if the new block has all of the same sensor locations and holes. more specifically the crank position sensor and cam position sensor since your old motor will probably have them and the new block probably picks it up off a sensor in the dist. if all else fail you could use you head you have now and use the new block. well good luck i dont know much about those motors but let us know how it goes
Old Mar 25, 2011 | 01:15 PM
well my block should be cool. but my head is cracked. and i dont think dist motors have the cam sensor hole. i found a completely rebuilt TOYOTA head on ebay for 375 so i might go that way.
http://cgi.ebay.com/ebaymotors/TOYOT...ht_3554wt_1165
tj884Rdlx
Aug 28, 2015 12:04 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
4Runnin2000
Jul 29, 2015 06:09 PM
nonstop
Jul 24, 2015 06:29 PM
