Help Diagnose Drive Belt Noise Area 2001 Tacoma 3RZ-FE 2.7 L
Old Mar 26, 2011 | 02:07 PM
TacomaNerd's Avatar
Hi Guys,
Was wondering if you could please help me diagnose the sound coming from my drive belt area. I have a 2001 4x4 Tacoma 3RZ-FE 2.7 L, manual transmission.
I thought the noise might of been my drive belts, so I replaced all 3 belts. Power Steering, Alternator, and Compressor belt. All the pulley's seems fine when I checked it as I replaced the belts.
It seems to only make the noise on cold start, and i notice the noise getting louder if I press on the gas or if i turn the steering wheel. Power steering fluid is full, might be old tho, but not sure if that matters. Once the engine is warm and I start to drive, the noise goes away.
Any ideas?
See Video.
http://www.youtube.com/watch?v=a7JztwsVR6w
Old Mar 26, 2011 | 07:58 PM
drift_king's Avatar
i could be wrong but it seems to me like u really dont have anything to worry about. cars do weird things when cold and its completely normal, because things expand and contract with temp changes, id say if u start here the noise while drive, after it warmed up id worry but until then i wouldnt worry, if someone else think this is a problem i welcome u to correct me but im sure u have nothing to worry about
Old Mar 28, 2011 | 07:20 AM
profuse007's Avatar
can't watch that vid yet. I get that problem quite some times after the belts are worn out but a quick tighten of belts' tension usually does the trick.
Old Mar 28, 2011 | 07:30 PM
TacomaNerd's Avatar
FYI.
I change the power steering fluid, there was some gunk stuck at the bottom of the reservoir. Problem fix.
mskalmus
May 28, 2017 07:51 AM
Yota.Jay
Jul 23, 2015 08:08 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
