CV boots ripped after lift, how to fix?
Old 03-03-2011, 07:04 AM
Mason Dixon's Avatar
I think I read that you can get oversized or extended boots to put on so they don't keep ripping. Is this what everybody does?
Btw, I do have the differential spacers.
Old 03-03-2011, 07:07 AM
askcheeks's Avatar
what kind of lift to you have? 4 inch bracket? are your torsion bars cranked?
Old 03-03-2011, 07:08 AM
3" OEM lift
Old 03-03-2011, 07:12 AM
mt_goat's Avatar
So you are running with an extreme CV angle and you are ripping boots? Lower the front down or get a diff drop kit is the answer to that question. The boots tearing isn't the worst thing about that, just wait till you blow the whole joint for the real problem.
Old 03-03-2011, 07:14 AM
I've got the differential drop and they still ripped. I don't do much wheeling either.
Would like to get some kind of extended cv boot kit so this doesn't happen again, just can't seem to find one on google.
Old 03-03-2011, 07:16 AM
mt_goat's Avatar
Post up a pic or 2 of the front CV angles, lets have a looksy. Are they OEM boots?
Old 03-03-2011, 07:21 AM
They are OEM, they definitely are in need of replacing that I have been putting off for too long.
I'm at work now so can't take a picture.
Old 03-03-2011, 07:44 AM
Whats the difference between high angle and long travel cv's?
Old 03-03-2011, 07:53 AM
scuba's Avatar
https://www.yotatech.com/forums/f2/0...cement-229699/
Old 03-03-2011, 07:54 AM
johnwoo's Avatar
just put my 3" lift with the same problem. of course the boots are old and in need of replacing was going to just replace the axle as i've read its easier. i would also like to know if there are heavy duty boots i can stick on there to prevent future tearing. and like op i have diff drop also
Old 03-03-2011, 08:34 PM
ReconCmdr's Avatar
Mine ripped after I did my toytec ultimate lift with diff drop. My mechanic and I chalked it up to the fact that the boots were 13 yrs old and all they needed to rip was just the little bit of change introduced. I chose to replace with new axles as the boot that ripped was the inside boot. By the time I paid for labor I could replace the axle for just a little more, so thats what I chose to do. As a nice benefit the new axles totally got rid of my high speed shimmy.
Old 03-03-2011, 09:17 PM
Ron Helmuth's Avatar
see T4R.org. I believe members over there have encountered this. DUhockey is a great guy and may be able to shed some light.
Old 03-06-2011, 09:59 PM
t4r4life's Avatar
diff drop would reduce the angel should help a lot
icentropy
09-16-2020 02:47 PM
jasonty
41
12-23-2018 01:00 PM
BeMiceElf
10-10-2015 09:40 PM
coffey50
07-28-2015 10:55 AM
PlayAwhile
07-20-2015 11:36 AM
Quick Reply: CV boots ripped after lift, how to fix?
