massive oil consumption 3.4L
Old Mar 2, 2011 | 09:00 PM
starbase89's Avatar
Hey.
I have a 96 4Runner SR5 with a 3.4 liter V6 and 152,400 miles. I last changed my oil & filter 600 miles prior, and since then, I have lost two and a half quarts of oil. I knew it had a minor leak or consumption issue, as I had been loosing half a quart per 4000 miles. l I can find no leak, and there are no stains on my driveway. Any ideas of what can cause something this severe?
By the way, there is no smoke, no error codes, and the engine is running relatively smoothly.
Old Mar 3, 2011 | 08:09 AM
Kiroshu's Avatar
Losing a half a quart every 4k miles is quite normal.
Sure you put enough oil in it upon oil change?
Loose oil filter?
Old Mar 3, 2011 | 08:20 AM
J2F42C's Avatar
Leaking valve cover gasket, cam seal plug, spark plug tube seals, oil cooler o-rings, rear main seal are possibilities. Crawl underneath to garner a look for leaks.
Did you change the brand/viscosity of the oil?
What is the compression #'s on the engine?
Old Mar 3, 2011 | 09:01 AM
jonnydclark's Avatar
Last time my 3.4 did that the oil filter was extremely loose.... there was a puddle developing though.
Old Mar 3, 2011 | 07:07 PM
BigBallsMcFalls's Avatar
some oil can dump into the skid plates and dribble out when you
are driving around. get home, the last drips stay in the skid plate
so you might still be dripping but not know it
Old Mar 3, 2011 | 08:19 PM
starbase89's Avatar
I have examined all around the engine and can find no oil. The skid plates on the truck are currently off (but due to be put back on). The oil filter is tight as it should be.
I checked compression a few months ago and got 175 across the board
Colington
Mar 8, 2020 09:51 AM
irritech
Jul 27, 2015 05:15 PM
1996Taco
Jul 20, 2015 12:02 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
