IPF 968 wiring help
Old Mar 26, 2011 | 05:05 PM
snoozer's Avatar
IPF 968 wiring help
So, I'm finally getting around to wiring up my IPF 968s and I want to make sure I'm doing this right. A few questions:
1. Can I share the ground for the battery terminal (green circle) with the relay mount? Can I use that same ground for the lights and/or relay? Is the red circled screw an acceptable ground location?
Uploaded with ImageShack.us
2. This set of wires connects the relay to the switch using the two black wires. The yellow wire is supposed to be used to connect the IPFs to the high beams. I want to use a Toyota fog light switch to control the IPFs. What do I do with the yellow wire?
3. To connect the switch harness to the the Toyota switch, I need to cut off the IPF switch, crimp the wires into disconnects, and connect to the switch, correct? I have red, black, and white wires. Which prong goes with which color?
4. What's the best way to run the wires through the firewall?
Thanks in advance. Wiring is clearly not my forte.
P.S. Here are a couple pages I've been referencing so far for anyone who uses this post in the future with their own wiring needs.
http://www.4x4wire.com/toyota/4Runner/tech/switch/
http://www.ttora.com/wiki/index.php/...ving/Fog_Lamps
Old Mar 27, 2011 | 08:59 AM
snoozer's Avatar
I found this installation on an FJ:
IPF 968 Full install guide - Page 2 - Toyota FJ Cruiser Forum
One difference between the FJ and the 3rd gen Runner is the ignition fuse is 10A on the FJ and 7.5A on the 4Runner.
If I used one of these to connect to the IGN fuse like he did, would I re-use the 7.5A ignition fuse in the first slot and a 10A fuse in the slot with the wire (which would connect to the yellow wire from the IPF harness)?
80Truck
Oct 12, 2025 07:25 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
ToyoToler
Aug 8, 2015 08:43 AM
Daneums
Jul 28, 2015 11:57 AM
TDonkey
Jul 26, 2015 10:14 AM
