RPM range expected with 4.88 Gears?
Old Mar 3, 2011 | 11:32 PM
traxxi2003's Avatar
Ok, so I searched and searched some more trying to figure out what would be the RPM range with 4.88 gears while doing 65 mph, bu tno luck. The gearing charts I found seems tobe way off or don't really apply to our trucks.
I own a 1997 4Runner SR5 2WD, I just installed new 33x12.5x15 tires on it and still running factory 4.10 gears. Right now with factory gears, the RPM @ 65mph, ranges between 1950 & 2050 RPM. How much higher will the RPM be with 4.88 gears while doing 65mph? Thanks!
Old Mar 4, 2011 | 03:18 AM
MaK92-4RnR's Avatar
Well... i dont know if this will help. but I have a 3.0 with 33s and 4.88s and i run at around 3100 RPMs. itll be different with yours though.
Old Mar 4, 2011 | 05:37 AM
mt_goat's Avatar
Use this one, it has our Toyota transmissions programed into it (just select your tranny) and it will be right on. http://www.ttora.com/forum/showthread.php?t=56784
Old Mar 4, 2011 | 09:35 AM
scuba's Avatar
http://www.grimmjeeper.com/gears.html
Old Mar 4, 2011 | 09:44 AM
mt_goat's Avatar
Originally Posted by scuba
Yep that's the same one, just a more direct link. I like using the other link because it has more instructions for newbies.
Old Mar 4, 2011 | 10:23 AM
xxxtreme22r's Avatar
mt_goat that calculator rocks, thanks for the link.
smthwsn357
May 1, 2024 07:28 AM
XtraCab
Apr 12, 2020 05:25 AM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
jaretstuff
Aug 4, 2015 02:08 PM
