Wheels siezed to hubs and stripped lug bolts - YotaTech Forums
LinkBack Thread Tools Search this Thread
Old 03-04-2011, 09:17 PM   #1
I've got a set of newer 2005+ 16" Tacoma wheels on my '99 Tacoma. When I take them off to swap on the winter wheels I've noticed the wheels like to sieze themselves to the hubs. I've improved the situation by lubing the hub faces with copper anti-sieze. I've also had a few lug nuts partially strip upon removal. Has anyone had similar problems, and found a solution?
ian951 is offline   Reply With Quote
Old 03-04-2011, 10:03 PM   #2
ToyoTech559's Avatar
rotate your tires often and clean the areas often if rust shows. i dont know what kinda of spray you can use to help prevent rusting.
ToyoTech559 is offline   Reply With Quote
Old 03-04-2011, 10:32 PM   #3
theMonch's Avatar
And in addition. Aluminum and steel don't corrode well together. If the rims (or especially lugs) are aluminum and the spinles are steel they tend to try to fuse themselves together.
Last year I replaced my stock lugs with some aluminum lugs that I picked up with the intent of ridding myself of the partially rusted not asthetically pleasing stockers.
Within 6 months the aluminum lugs corroded and seized themselves to the studs so bad that I had to drill 6 of them down in their entirety (lugs and studs) to get the wheels back off.
I tried everything to avoid from having to do this... pentrant oils, heat, leverage, etc. But once there welded on there chemically...good luck.
And to note. they were put on with a healthy dose of anti-seize and this was still the results.
theMonch is offline   Reply With Quote
Old 03-05-2011, 02:04 AM   #4
totally a bro
Staff
vital22re's Avatar
A good cleaning with a wire wheel attachment on a drill and NOT copper antisieze but the silver stuff.
vital22re is offline   Reply With Quote
Old 03-05-2011, 05:14 AM   #5
wifes4now's Avatar
Quote:
^^^^^^^^^^ x2
get everything super clean.
check to make sure the hub hole on the wheel has not become out of round, or has been squished.
if so, lightly grind out the weird spots.
lots of anti-sieze (i use silver).
wifes4now is offline   Reply With Quote
Old 03-05-2011, 07:33 AM   #6
mt_goat's Avatar
Quote:
I'd recommend just a thin coat, if you get too thick you run some risks of the wheel loosening up on you, be especially careful about getting it down in blind hole lug nuts so you don't hydro lock the fastener. Re-torquing after about 50 miles would probably be smart with anti-seize use.
mt_goat is offline   Reply With Quote
Old 03-05-2011, 07:58 PM   #7
BigBallsMcFalls's Avatar
rotate tires every 5000 miles and it solves the problem...usually
BigBallsMcFalls is offline   Reply With Quote
Old 03-06-2011, 06:26 AM   #8
cpizzle42's Avatar
Or you can just move to Arizona???
cpizzle42 is offline   Reply With Quote
Old 03-06-2011, 08:22 AM   #9
vapor barrier plastic between the steel hub and alum rim will stop the 2 from seizing together. Zinc based anti-seize will stop the nuts seizing. A light coat of white grease will also do.
MudSir is offline   Reply With Quote
1991 Pickup - 3VZE fuel line / filter stripped out. How to replace? pyramid 86-95 Trucks & 4Runners 10 07-30-2015 10:05 AM
Troubleshooting my 1993 22re PlayAwhile 86-95 Trucks & 4Runners 5 07-20-2015 11:36 AM
Inner hub bearing glowz825 95.5-2004 Tacomas & 96-2002 4Runners 4 07-17-2015 12:28 PM
Auto hub issue Steven.m.paulk 86-95 Trucks & 4Runners 5 07-13-2015 01:40 PM
85 front axle hub dowel pins? oldirtydirt 84-85 Trucks & 4Runners 0 07-12-2015 11:21 PM
Tags
1988, 4runner, 93, bolt, locks, lug, lugbolt, lugs, rear, removal, stipped, stippped, stripped, toyota, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2017 InternetBrands, Inc.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
