Piston slap( carbon knock) or Rod? After Seafoam..any thoughts
Old Mar 2, 2011 | 07:59 AM
chris383's Avatar
Hi, I added some seafoam to my engine, through the PCV valve, slowly. Engine did not stall out. started it, smoked, ran fine.
I drove it to my girlfriends (70 kms) and on the way home, about 5 min from my house, it started to knock. Sounds like a rod knock. It goes away at idle, and even at low speeds, but comes back at about 1500 rpm +
any thoughts?
This all occoured AFTER it had run for about 110-120 kmns from the treatment
If its any help., I have vbeen getting a code for 0301 from CYL1 misfiring.
Did I throw a rod, any easy way to diagnose it before it goes to the garage?
Old Mar 2, 2011 | 08:02 AM
Potomacduck's Avatar
If you threw a rod your rig would not have left the driveway.
I will take a wild guess and say you may have a burned valve.
Keep us updated on this one.
Old Mar 2, 2011 | 09:34 AM
chris383's Avatar
Thanks. I know I didnt throw a rod DURING the application, but is it common at all to have it go during cruising at 110km/h? I literally had the cruise on the whole way home, got off the highway on a ramp, and after I got going again at the stop sign, the knock was there.
Any tips on diagnosing? What about Carbon knock?
Thanks again
Old Mar 2, 2011 | 07:06 PM
BigBallsMcFalls's Avatar
tune-up in a can and then engine noise afterward ?
time to pull it apart, tune-up with your hands
Old Mar 3, 2011 | 05:19 AM
blake.nemitz's Avatar
chain slap inside timing cover?
Old Mar 3, 2011 | 06:59 AM
ah i see sometimes a dirty motor isnt such a bad thing when i seafoamed my buddies 4.0 jeep yea i know heep! it started leaking out the rear main and oil pan gasket.
Old Mar 4, 2011 | 06:43 PM
Texas_Ace's Avatar
It depends on how loud it is really. Also did you put it in the oil (please say no)?
I always change my oil after a seafoam/water treatment. It will get into the oil and will break it down. So i always do it just before an oil change.
bigjstang
Jun 2, 2025 03:56 PM
thefishguy77
Jul 30, 2015 10:59 AM
ShakinIt2x
Jul 21, 2015 06:20 PM
keithporter83
Jul 18, 2015 12:37 PM
Edionne13
Jul 9, 2015 01:59 PM
