Suspension Recommendations
Old Apr 15, 2011 | 12:03 PM
OnMy3rdTac's Avatar
Thumbs up Suspension Recommendations
Truck Specs:
2002 Tacoma Extended cab SR5
2.7L Automatic
144,xxx miles
First off, I've been a long time stalker on this site, but never posted before, thanks for the help over the years. I'm currently on my third Toyota truck, and for the first time I need to deal with the suspension. (the ride is a little too bumpy and the back leaf springs are bending in the wrong direction)
Through all my research it looks like the Bilstien 5100's are a popular choice for shocks and struts. I was thinking about combing the rear shocks with the wheelersoffroad HD Leafspring kit for 1.5in lift. (I don't need a lift, but hey maybe it'll help the 4 times a year I'm offroading)
I have a few questions/concerns about my plan, as i don't know too much about suspensions:
First, do i need/want to replace my front coil springs when I do the front struts? If so, what would you recommend to go with the Billies set at a 1.5" lift? If not, can I set the new Bilstiens at 1.5 with my existing Springs?(this doesn't seem like it should work)
Second, I'm not loaded, so I was thinking of doing this in two stages, the rear, then the front. Any reason to do it all at once?
Third, as I don't off road too much, and my truck spends most of its time on the freeway, are there any other products I should be looking at for my Toy?
Thanks for all the help!
-Markus
Old Apr 15, 2011 | 12:12 PM
warpigg's Avatar
you will probolly get more lift then 1.5 with that spring and shock combo. and i would use a softer shock in the rear sense you have a pick up. and you dont have to do the front at the same time as the rear, and if you use a lift setting on those shocks it will make them stiffer giving you a bumpy ride.
Longbed 90
Mar 11, 2019 12:38 PM
Scottcrb
Mar 3, 2016 11:57 AM
Swampwalker
Oct 12, 2015 09:49 AM
87blyota
Sep 14, 2015 08:38 PM
justdifferentials
Sep 5, 2015 06:52 PM
