Toytech 3" Spacer Lift Kit????
Old Mar 30, 2011 | 12:34 AM
traxxi2003's Avatar
Ok, You all know that the lift kit mentioned in the title comes with spacers for thr front struts and with longer coils in the rear to achieve a combined 3" lift. BTW I installed one of this on my 1997 4Runner SR5 2WD. With the kit installed my truck looks like it seats a bit higher than the front. Is this a known issue with this types of kits? I kept the factory front coils. Could this be the cause? Also toytech sales a thin spacer that is used to correct the driver's side front height. Does anybody had the same problem?
Here is a picture of my truck, although this pic barely shows the difference in height front to back:
Old Mar 30, 2011 | 04:38 AM
waskillywabbit's Avatar
Front lower is the normal rake of the vehicles stock suspension.
I've installed dozens of these lifts and never had to balance out one left/right with a trim packer.
If it's off that way the better option would be new coilivers up front as your front coils/shocks are worn out.
:wabbit2:
Old Mar 30, 2011 | 09:44 AM
ricky's Avatar
Pretty sure those trim packers are ONLY for the OME coilover setup, but I might be wrong.
Looks good.
Old Aug 13, 2011 | 06:21 AM
SHAWNB's Avatar
I have a question about this system, i recently replaced my front struts with bilstein hd's because they originals were worn out and i need to also replace my rear's but i want to get the toytec 3" kit that comes with the spacers in the front and the longer coil springs in the rear, my question is do i need to buy longer rear struts or will the factory length bilstein hds work? Since i have to buy new rear struts anyway i just need to know which length?? Any help would be apreciated.
Old Aug 13, 2011 | 11:20 AM
TheDoodie2's Avatar
You have shocks on the rear. And yes you will need longer shocks. And yes your factory shocks might work but they will be over extended and fail in a short time.
Hope that helped.
Old Aug 23, 2011 | 06:16 PM
superswamper003's Avatar
I have some revtek spacers on my taco and it rides really rough :/ the whole thing is like falling apart.
Old Aug 27, 2011 | 09:43 AM
ToyTec Lifts's Avatar
Sponsoring Vendor
Looks good.
You are correct. The front trim packers are for the OME coil overs. As the OP stated, we do sell a 1/4" top plate spacer to correct the driver side lean.
http://www.toyteclifts.com/index.php...mart&Itemid=72
The stock rear shocks will work with this set up. However, we do recommend replacing them for the best ride quality possible. I would recommend going with a Bilstein 5125 in the rear. That's what I have in my 3rd gen and it rides great!
If you have any further questions feel free to give us a call. My extension is 107.
Thanks,
Jeff
Sep 4, 2015 09:27 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
coffey50
Jul 28, 2015 10:55 AM
kirkrunner
Jul 27, 2015 07:59 PM
