Fixing my turn signals...
Old Mar 23, 2011 | 11:46 AM
sickyota925's Avatar
Arrow Fixing my turn signals...
So i just got a 2000 4runner for a really good price because the bumper is messed up. the lower valance is gone and has no lower tun signal housings. Because it is missing the lower the turn signals the upper front corner signals dont work and the rear signals flash really fast. Is there any way to bypass the lower signals and just use top corner signals?
any insight would be great thanks!
Old Mar 23, 2011 | 12:23 PM
scuba's Avatar
The top corner lights are only marker lights. They don't blink. Stick a bulb in the lower turn signal sockets (the sockets are hanging somewhere back there, right?) and the hyper blink will probably stop.
Old Mar 23, 2011 | 12:51 PM
tj884Rdlx's Avatar
you would need a double filament bulb and a 3 wire socket to make that happen. it's a popular "mod" to do for older trucks; you can certainly do it too.
you'll have to route the wires which feed the turn signal blink over to the corners, and replace the existing socket. or else, squeeze in a second socket. a dremel makes modifying the housings very easy.
you may need a universal flasher relay to eliminate the quick-flashing. stock relays notice the change in resistance and flash faster to alert you of a burnt bulb. some universals are made without this extra feature.
Old Mar 24, 2011 | 03:04 PM
ED ROCK's Avatar
You can do this to use the marker lights as turn signals, they will still blink fast, unless you add a resistor or use the stock signals also.
http://www.danielsternlighting.com/t...rkerflash.html
Old Mar 24, 2011 | 07:02 PM
Ron Helmuth's Avatar
a number of us have added a 2nd bulb to the corner marker lights-YotaTech member "RitzyRunner" authored the writeup I would recommend. I may even have another pair of Honda push in bulb receptacles if you decide to go that route.
That way the corner lights are still "parking" lights and when turn signal is engaged they also have a bulb for that function as well.
ashersullivan88yota
Jan 18, 2022 05:37 PM
jasonty
41
Dec 23, 2018 01:00 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
yourrealdad
Jul 21, 2015 11:13 AM
smiley52
Jul 11, 2015 05:16 AM
