Old Mar 31, 2016, 03:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner 4WD - Four Wheel Drive Guides
Print Wikipost
4WD Transfer Case Actuator
Old Feb 16, 2007 | 03:32 AM
Potomacduck's Avatar
I have a '99 Limited. The other day I pushed the 4WD button on the transfer case lever which puts the vehicle into 4WD "open" mode. Everything worked fine until I pushed the button to put it back into 2WD. It would not go back into 2WD.
I went to the dealer and here's what happened. The service writer said the acutator is broken. It's a $900 part and requires 13 hours of labor because it requires removing the transfer case etc. Bottom line: $2,300 for the fix.
I asked the mechanic if he could get it back into 2WD for me. The mechanic said, no problem. He switched the two vacuum lines located in the engine compartment above the drivers side wheel well. OK, so now it's back in 2WD, but the dash light still flashes.
Question: if switching the two vacuum lines put the vehicle back into 2 WD, then is the transfer case actuator really the problem?
Old Feb 16, 2007 | 10:27 AM
GSGALLANT's Avatar
What he did by switching your vacuum lines was retract the ADD sleeve in your front diff. Your front driveshaft is likely still turning with your engine if the problem is in the transfer case. Get someone to look under the truck as you drive it slowly to see if your front driveshaft is turning. If you do get the transfer case fixed, don't forget to swap those vacuum lines again to get it to work correctly.
Old Feb 20, 2007 | 03:13 AM
Anyone else?
Old Feb 20, 2007 | 06:32 AM
GSGALLANT's Avatar
So... did you check your driveshaft or not?
Old Feb 20, 2007 | 08:53 AM
Yes, the front propeller shaft is turning. The problem is the actuator which is external to the transfer case, but it is pinned inside the transfer case, so it's big job to install a new acutator.
Old Feb 20, 2007 | 08:54 AM
terryjmatthew's Avatar
I am having a similar problem with my 2001. I am going to get a used case for cheaper than the actuator itself.
Old Sep 25, 2007 | 05:25 AM
vtruong1's Avatar
Haveing the same exact problem with my 99 Limited.....what did you end up doing? I have been driving around with flashing lights and a disengaged ADD sleeve.
4x4-runner
Dec 27, 2016 01:58 PM
Chumlee780
Nov 13, 2015 03:18 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
yourrealdad
Jul 29, 2015 11:08 AM
crashburnoveride
Jul 10, 2015 06:39 AM
