How Wide Is To Wide?
Old Feb 19, 2007 | 04:42 PM
kodiak2000's Avatar
I have a 2000 4Runner with the 2.7L and I have a few questions regarding tires:
1. I currently run 235's. I would like to go to a larger tires size, 30 or 31's, but I'm concerned about rocks being thrown up against the body by the tires because I don't have fender flares. So how wide of a tire can I go to and still avoid this?
2. Can a 2.7L reasonable manage 30 or 31's?
Thanks
Old Feb 19, 2007 | 05:46 PM
CLEANSR5's Avatar
Not much to help, but to answer your question this is too wide:
https://www.yotatech.com/forums/f2/ridiculously-huge-toy-pu-107679/
Old Feb 19, 2007 | 05:49 PM
kodiak2000's Avatar
Yeah, that's a little wider then that what I was imagining!
Old Feb 19, 2007 | 05:52 PM
89silverpu's Avatar
I don't know much about a 2000 runner but my 89 pickup has 31's and my 22re has no problem i can still go about 80 on the free way, and i don't have any problems with rocks messin my paint up.
Old Feb 19, 2007 | 05:54 PM
EWAYota's Avatar
you could get some 30x10.5 or 31x10.5's and you should still be inside your wheel well.
as far as can the 2.7 turn them, sure. People run 33, 35, 36 with 4.10's on the 22RE (2.4). If you go larger than 31's, you might want to start thinking about regearing.
your speedometer might be off a bit if you upgrade tire sizes but theres plenty of calculaters and simple tricks online to show you what your actually doing when your speedo says 35 mph.
Old Feb 19, 2007 | 05:55 PM
kodiak2000's Avatar
Thanks
Old Feb 20, 2007 | 03:58 PM
tacoma728's Avatar
it has a lot of torque still with the 33x12.50s, but no highway power whatsoever. Then again, i only have 3.42 gears. They suck, that's just the bottom line.
Old Feb 20, 2007 | 04:16 PM
norcalsvx's Avatar
i run 33's on stock gears with a 22re, i wish i had the 2.7l
Old Feb 20, 2007 | 06:39 PM
EWAYota's Avatar
I don't mind my 22RE with 33's and stock gears, only since I don't drive alot on the freeway. 4.88s or 5.29's are in the picture but so are possible 35s.
Bourbonblues
Dec 15, 2017 05:43 PM
Jgloade
Aug 29, 2015 08:40 PM
toystoplay
Aug 25, 2015 11:54 PM
Sidherish
Aug 3, 2015 07:17 PM
Suprarossa
Jul 6, 2015 05:21 AM
