Pic Request: LC Rims with 265/75/16
Old Feb 24, 2007 | 05:52 PM
mpavolka's Avatar
Does anybody have any pictures of FJ80 Rims with 265/75/16 inch tire on a 3rd gen 4Runner? Anybody think they will rub under a full stuff?
Old Feb 24, 2007 | 05:54 PM
Localmotion's Avatar
do you want fj80s or fZj 80?
Old Feb 24, 2007 | 06:18 PM
mpavolka's Avatar
I was looking at getting the aluminum 16x8 five spokes that come on say a 1995 Land Cruiser , what is the difference?
Old Feb 24, 2007 | 06:35 PM
habanero's Avatar
Saw this not too long ago...
https://www.yotatech.com/forums/f2/lifted-refinished-lc-wheels-revos-big-pics-90829/
Old Feb 24, 2007 | 06:37 PM
namekim99's Avatar
heres some pictures i had over the the summer, i'm running 265/75/16 BFG KO, Haven't had a chance to see it fully stuffed yet. so i couldn't say, but i did have to do some trimming to my limited flares in the front
namekim99's Avatar
Sorry forgot to put the link to the tread i had with the pictures
https://www.yotatech.com/forums/f2/flexing-river-crossing-pics-86926/
Old Feb 24, 2007 | 07:40 PM
mpavolka's Avatar
What is the offset on those wheels compared to stock 3rd gen? In other words does it give the car a wider stance/how much?
Old Feb 24, 2007 | 10:18 PM
d0ubledown's Avatar
they will give a wider stance yes. theyre 1" wider than stock as well as being .25" (i think..correct me if im wrong) shallower BS. so they'll stick out a touch more.
i know you want em with a 265, but for reference, heres 285's. the 32's will be slightly smaller of course, but with this angle you can see how they're nicely flush with a LTD flare...
and of course with a 315 they're just down right bulgy..
Old Feb 24, 2007 | 10:56 PM
garrett1478's Avatar
i have 265/75/16s on LC wheels... they rub a little at about half turn with some compression... havent tried stuffing them yet
Old Feb 24, 2007 | 11:34 PM
mpavolka's Avatar
With tundra coils and 1 top spacer in the front I should probably be good though, right? Beeing that the tires are only 265's. By the way thanks, for all the help from everybody.
Old Feb 24, 2007 | 11:46 PM
marko3xl3's Avatar
You don't need anything to make 265/75/16s fit. That's the largest tire size that will fit on a 3rd gen without rubbing.
That has been answered many times on this forum though
Old Feb 25, 2007 | 09:46 AM
that's with stock rims, 7" wide. things change with an 8" wide rim.
Old Feb 25, 2007 | 05:59 PM
mpavolka's Avatar
Yea, I am going to look carefully when I turn to see what gaps I have in between the fenders before I buy a set. From what I have read I think that as long as I have over a half inch I will be ok. This is just what I think, but if the wheel is an inch wider, then the actual tread of the tire should only move a little over a half inch, because the tire is still mounted on the inside of the rim, but then again I heard that the offset is .25" different. I think those wheels look cool, so I will just make them fit, I think it will be fine though
Old Feb 25, 2007 | 06:29 PM
rocktown's Avatar
alot of people run 285's and 305's on LC wheels and they actually give more clearance between the tire and upper control arm than the stock wheels. With the lc wheels you wont be rubbing the UCA, but you may need to trim the fender flares a little.
chukarhunt
Dec 8, 2019 11:39 AM
Jamie4runner2000
Jun 20, 2016 09:13 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
Yotoder865
Jul 9, 2015 07:51 PM
