Coolant temp.
Old Feb 26, 2007 | 03:07 PM
KGSC68's Avatar
Coolant temp.
I have a question about coolant temp. My gauge has always read just above half way. All other Toyotas that I have owned have read just below half way. I asked a question about this in this forum a good while back and some said that theirs read the same as mine. I have changed the themostat and the temp. sensor and the reading is the same. I have also ran the truck to operating temp. and popped off the radiator cap to check the temp with a thermometer. It read 170 F. I believe that the thermostat is a 185. Does this seem right? Thanks for any info. (2000 4x4 3.4L)
Old Feb 26, 2007 | 03:11 PM
Elton's Avatar
mine sits right in the middle and it dont move and the last two trucks i had always where just a little below the half way mark
Old Feb 26, 2007 | 04:11 PM
MTL_4runner's Avatar
Have you done a coolant flush?
What is the ratio of coolant to water you have in there now?
Old Feb 26, 2007 | 05:01 PM
mtnwheeling's Avatar
That isn't really anything to worry about. As long as it is consistent you should be fine. I have had several toyotas and they all sit in a different place...just above half, just below half, right in the middle.
Old Feb 26, 2007 | 05:07 PM
mt_goat's Avatar
Have someone hook up an OBDII reader and check the temp that way.
Or buy one and do it yourself: http://www.urdusa.com/product_info.p...s_id=840100000
Old Feb 27, 2007 | 02:44 PM
KGSC68's Avatar
I replaced the coolant but did not do a flush. I'm not sure about the ratio.
Old Feb 27, 2007 | 04:09 PM
pmbazus's Avatar
Coolant temp.
Mine has read above the center from the day I bought it new. I changed thermostat, coolant and it still read the same. I now have a ScanGuage II and the temperature reading is right where it should be around 180. The Toyota guage shows it a little bit above center.
ladybugRC
458
Aug 21, 2020 10:41 AM
wberry85
May 17, 2016 05:45 PM
alexcarey
Oct 14, 2015 06:05 PM
kcaudill
Oct 10, 2015 02:39 PM
rmill05
Sep 27, 2015 01:43 PM
