96 Tacoma Cab Swap
Old Feb 26, 2007 | 09:28 PM
Doozy's Avatar
96 Tacoma Cab Swap
About 4 months ago my 1996 Ex Cab Tacoma was totalled. Long Story Short I have most of it left including the Cab that is in perfect condition. I just recently came across a rolled/totalled 96 Regular Cab Tacoma that I can buy for $1200. I was wanting to know if it's possible to put my Ex Cab body on the Regular Cab Frame and turn it into a flat bed. I realize I'll most likely have to move the rear two body mounts, but other than that, does anyone know if this is a nightmare of a project? Or is it something that can be figured out by someone that somewhat mechanical? I've done a dozen or so engines and full Interiors but never touched a cab. Any help or advice would be greatly appriciated. Thanks in advance.
Old Feb 26, 2007 | 09:29 PM
DeathCougar's Avatar
You pretty much answered it already. You will have to move body mounts around. Plus, the reg cab frame is shorter, thus you will have to either fab a short flatbed, or modify your bed to fit.
Old Feb 27, 2007 | 08:15 AM
breknraj's Avatar
Also, since the donor has been rolled, you would be wise to take some measurements to be sure that the frame has not been bent. That would be a lot of work to do, and then discover that it doesn't drive well!
smthwsn357
May 1, 2024 07:28 AM
Poncho0206
Jul 10, 2015 06:21 PM
akaphilly
Jul 9, 2015 02:18 PM
Cplmike
Jul 8, 2015 08:47 PM
elwood73
Jul 5, 2015 07:07 AM
