LC Springs Question?
Old Feb 15, 2007 | 01:00 PM
frodin1's Avatar
Does anyone know if the front springs off a 97 LX "LC" work for the rear of my 3rd Gen? I'm just trying to do this right! Please help.
Old Feb 15, 2007 | 02:37 PM
BajaRunner's Avatar
I think 97 = FJ-80. As long as it has a solid front axle, then I think you're good to go.
Old Feb 15, 2007 | 03:18 PM
frodin1's Avatar
I've gotten mixed answers on those and weather or not to replace bump stops? Opions? I dont do any heavy roading. Can I just keep the stock stops?
Old Feb 15, 2007 | 03:20 PM
EuphoricKaty80's Avatar
J powder coated a set of LC springs for a guy with what i believe was a 3rd gen and he was planning on putting them on the rear. From what i hear they should fit.
Old Feb 15, 2007 | 04:05 PM
BajaRunner's Avatar
I am using front FJ-80 coils in the rear of my truck, with stock cone stops and bump stops.
It just is important that you get these from the correct vehicle. I'm pretty certain the FJ-80s were still in production in 97...possibly the last year of them.
Old Feb 15, 2007 | 04:23 PM
GREEN4SKIN'R's Avatar
You are correct. Rumor has it that the LX springs are softer than the Landcruiser's. Both the Lexus and Toyota are technically FZJ80's.
Old Feb 15, 2007 | 05:06 PM
frodin1's Avatar
Ok cool, a couple people have told me now, not to worry about the stops if I don't wheel much. I'm just getting a boat and I would like it to sit level when I tow. I already have the 2.5 inch daystar lift. Just looking to replace the spacers in back and gain another inch or so.
Old Feb 15, 2007 | 06:01 PM
ROOFGOOF's Avatar
Yeah 91-97 years will work. You will get a rake look to your rig once you put them in.
Good luck!
Old Feb 15, 2007 | 06:31 PM
frodin1's Avatar
Well not that much though? I'm already running the Daystar spacer lift "2.5" , So if I'm towing it shouldn't be sagging I dont think. I should only be gaining an inch over what I have now from what I've read.
Old Feb 15, 2007 | 09:16 PM
frodin1's Avatar
So buying shocks, Couldnt I just look up a Landcruiser stock shock for a 0" lift and it should work for the LC80 coils Im getting . Regardless of brand??? I was looking at ranchos. 3rd gen LC 80 spring lift and stock ranchos intended for a land cruiser rear. Stock Rancho LC RS5208 is for a stock land cruiser.
Old Feb 16, 2007 | 05:10 AM
ROOFGOOF's Avatar
Yeah, thats what I meant, you will have a slight rake look when sitting level under no load. (the rear being slightly higher).
I just installed LC coils on mine with LC shocks. (its still sitting in the garage though with the front end apart) so I can give any ride advice, etc as of yet.
Good luck.
Old Feb 16, 2007 | 07:04 AM
BajaRunner's Avatar
Thats what I'm running... LC coils/shocks. Actually Old man emu shocks, so they are a little longer. I am running 5-6" of lift back there though.
Old Feb 16, 2007 | 10:07 AM
frodin1's Avatar
Has anyone ever run procomp shocks? 4WP is have a sale for like 150 for all four? Just wondering if there just throw aways or is that a deal. When OME, And Bils, are like 70 + each, Ranchos are like 50ea.???
Old Feb 16, 2007 | 10:47 AM
frodin1's Avatar
Well I have a guy that'll sell me his front springs. Should wait 2 weeks to get the LX450 springs or should I start looking for actual LC coil springs?
Old Feb 18, 2007 | 08:53 AM
frodin1's Avatar
Not to beat a dead horse here, Is anyone running these 97' LX450 Coils and could you tell me the oreintation for them. What colors go on what side?
Old Feb 18, 2007 | 04:10 PM
ROOFGOOF's Avatar
Color codes really don't matter for 4runner use, just put the longer LC coil on the driver side to account for the gas tank weight, etc.
The biggest things to ask for when buying your coils used are:
What year?
How many miles?
Did the coils hold a brush gaurd, etc? (added weight which could have caused some sagging)
and......How much?
Old Feb 18, 2007 | 04:28 PM
frodin1's Avatar
I've gotten like 3 seperate people trying to sell me 97' LX 450 springs. But I'm leery to get them because I haven't found anyone thats actually put them on. Everyone seems to use like 93 or 95 coils I guess?? Should I go for it? All of them are asking $50 bucks. I got the LC shocks taken care of.
Old Feb 19, 2007 | 08:13 AM
frodin1's Avatar
Alright, I found the answer I'm looking for! The LX450 springs will work however you will not get the full lift that you would from the 93 LC springs.
This link actually shows the difference in height prior to instal and after! http://forum.ih8mud.com/showthread.php?t=45074&page=2
Old Feb 19, 2007 | 09:01 AM
ROOFGOOF's Avatar
yeah, it seems the old ones 91-93 ish will give sometimes OVER 4 inches of lift. I believe the ones I put on are from a 95 or 96. They are installed, but I have not done any measurements yet....soon to come.
Springs that are from 94-97 seem to range between 3.5 to 4 inches.
Old Feb 19, 2007 | 11:31 AM
ROOFGOOF's Avatar
https://www.yotatech.com/forums/show...light=lc+coils
Read up on the thread posted above...lots of info regarding those coils when guys first started putting them on.
nvdesertrunner
May 11, 2020 08:18 PM
delmert
Sep 30, 2015 04:34 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
defrag4
Jul 31, 2015 10:50 AM
coffey50
Jul 28, 2015 10:55 AM
