Steering column moves sideways?
Old Feb 22, 2007 | 05:46 PM
kkshyu's Avatar
For my 97 4Rynner SR5, auto, 3.4L, 4x4, is the steering column supposed to move a little when pushing it sideways? Is it the free-play? There is no signs of vibration when driving, though. Any comments or suggestions? Thanks.
Old Feb 23, 2007 | 06:52 AM
eric-the-red's Avatar
Is the column moving or just the wheel. If it really is the column look under the dash and there should be a bracket attaching the column to the body. Check that it hasn't come loose.
Old Feb 23, 2007 | 09:18 AM
kkshyu's Avatar
Thanks for reply. It is the column that moves. I will have a check under dash.
Old Feb 23, 2007 | 09:22 AM
MTL_4runner's Avatar
I agree, I think the column is loose under the dash.
You're not talking about the steering wheel adjuster are you?
Old Feb 23, 2007 | 09:45 PM
kkshyu's Avatar
What is the steering wheel adjuster? Will it affects my normal driving when the column moves just a little bit sideways? Thanks.
Old Feb 23, 2007 | 10:21 PM
TOYZILLA's Avatar
The column is held up by a bracket to the dash frame , I beleive there are four bolts or two. If all bolts came loose,you'll have the column on your lapp,Making it a little hard to drive. You need to check into this now.
jasonty
41
Dec 23, 2018 01:00 PM
gillesdetrail
Aug 3, 2015 04:43 PM
Shaun Crystal Gomban
Aug 2, 2015 08:00 PM
RBK
Aug 2, 2015 11:33 AM
toyoterferdayz
Diesel Swaps
Jul 27, 2015 05:25 PM
