PCV valve 2.7. Help!
Old Mar 1, 2007 | 06:41 AM
crazy_horse3030's Avatar
Unhappy PCV valve 2.7. Help!
does the pcv valve on the 2.7 liter 3rz-fe engine have threads or does it just pull straight out?
If it pulls straight out looks like I am going to need a crowbar to get it out.
Old Mar 1, 2007 | 07:35 AM
Skrillah's Avatar
It should just pull straight out...if it hasn't been replaced for a while...it may be a little tough. Get a set of pliers.
Old Mar 1, 2007 | 08:21 AM
pat161's Avatar
It either depends on the year or if it has CA emissions. Not sure which is the reason, but my 00 Runner w/ the 2.7 had a screw in style while my buddies 98 2.7 Runner was just a plug in style. So in summary, if it doesn't pop out easily don't resort to the crowbar until you try to unscrew it.
Old Mar 1, 2007 | 10:30 AM
Beartracker's Avatar
My 01, 2.7 looks like a spark plug and screws in. You need a ratchet and deep well socket. Can't remember the size but it's about like a spark plug as mentioned above. Get something to stand on if you have too and you will see what I'm talking about. Mike
Old Mar 1, 2007 | 11:23 AM
I got it out. It took a good pair of wire pliers. It had a lot of carbon around it and in it. I knocked carbon and oily stuff all over the place. It still rattled and pulled a vacuum, but I am going to replace it anyhow. I can afford 6 bucks.
thanks guys
LotOMiles
Sep 14, 2015 11:45 PM
ac7822
Sep 11, 2015 08:49 AM
Boomer8404
Sep 10, 2015 09:01 AM
idadan208
Sep 7, 2015 09:06 AM
