Gearing, for my 3rd Gen
Old Feb 22, 2007 | 10:56 AM
xcmountain80's Avatar
I know, according to my VIN my 2002 4Runner has 4:10 gears. I have since Lifted it added wheel spacers and 285/75/16's on stock limited wheels. I get about 17mgp with AT's and 15-16ish with MT's. I'm currently at 127k and will reach 200k in 1.5 years. I had intended to purchase a pre-owned 3.4 mill and add headers, URD SC kit, and a TRD SC, among other odds and ends. After researching the turnkey cost I started to think a bit. HMMMM I though instead of a SC I could re-gear both ends and ARB lock the rear, then when I need a motor just replace what I have no SC. So the question is which gears to go with? I never plan on anything bigger than the 285's seeing as how these seem perfect for the application. Would I need 4:88's or 5:29's? I do 80% highway for work and play and the other 20% offroad. I know the Expedition West Taco is running 5:29's. And most other Taco's are equipped with 4:30's. Though the ARB can only be geared with certain ratios.
Aaron
Old Feb 22, 2007 | 11:34 AM
BajaRunner's Avatar
If you don't plan on going bigger than 33's, 4.56's <-optimized for on-road mileage and capabilities. 4.88's and 33's will give you too much RPMs on the highway IMO.
Old Feb 22, 2007 | 04:58 PM
So hmmm can Arb's be fitted with 4:56's, if so can the front be fitted this way?
Aaron
Old Feb 22, 2007 | 05:24 PM
neliconcept's Avatar
Andy Bamachem has 4.56s with dual arbs i think.
Old Feb 22, 2007 | 05:59 PM
BajaRunner's Avatar
I didn't know that ARB's were gear specific. I think as long as you don't have an overly small gear ratio, where the ring is small, then you're okay.
Old Feb 22, 2007 | 07:08 PM
xonetruthcrewx's Avatar
i have 4.88's and dual ARB's with 285's. I too was a little skeptical on the 4.88's at first but went for it anyway. I love it. Truck does not rev too high during freeway driving at all. I pull about 2600 rpm at 75mph. I wouldnt want it any other way. Right On.
Old Feb 22, 2007 | 08:13 PM
spaugh's Avatar
forget the gears, get the SC and keep the 4.10's. You will have plenty of power then.
Old Feb 22, 2007 | 08:35 PM
BruceTS's Avatar
Ditto......
4.10's are much stronger and will hold up better with the SC.
smthwsn357
May 1, 2024 07:28 AM
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
HollieJayyy
Aug 9, 2015 07:59 AM
91yotapup
Jul 27, 2015 07:19 AM
