motor oil in my transfer case???
Old Feb 23, 2007 | 11:46 AM
mkgarrison5's Avatar
hey guys got a 2002 v6 4x4 tacoma and i forgot to mention this to you guys last week. when i drained my t-case it looked like nothing but motor oil came out.. no thick 75-90 oil but loose 5-30 type oil. same color of motor oil at like 1000 miles.. stained light brown color... i was like wtf and played with the oil bc i coulndt believe it.. its like someone put motor oil in there instead of 75-90 or whatever.. now i have used the 4 wheel drive a few times before i realized this but everything was fine.. whats your take on this?
Old Feb 23, 2007 | 11:50 AM
MudHippy's Avatar
Some fancy new synthetic, I PRAY. Might wanna flush it all out and just start from scratch. There are some transfer cases that require ATF fluid, none with motor oil, I'm aware of anyway. No that isn't correct some do need motor oil, maybe not Toyota.
Old Feb 23, 2007 | 11:57 AM
MTL_4runner's Avatar
Just drain and refill with the correct weight oil, it will be fine.
Old Feb 23, 2007 | 11:58 AM
no that year it calls for gear oil just like in the diff cases... i was pissed.. the funny thing is i bought it used at yota and its certified used car haha... some assholes
Old Feb 23, 2007 | 11:59 AM
i did but what idiot puts motor oil in a t-case? well for that year bc it states in the book 75-90
Old Feb 23, 2007 | 12:00 PM
Who knows?!
Just as long as you corrected it.
Old Feb 23, 2007 | 12:02 PM
Who knows?!
true but toyota has to inspect all fluids to get certification.. when i bought the truck the air filter was nasty as hell, now found motor oil in my t-case and when i changed the rear end diff right after i bought it was black... i called them and they acted stupid.. go figure... so if you live in NC dont go to Leith Toyota in Raleigh..
Old Feb 23, 2007 | 12:03 PM
OMG.....a car dealer that lied to you.
I'm sorry but that's just not possible!!!
Old Feb 23, 2007 | 12:04 PM
yeah yeah yeah
Old Feb 23, 2007 | 12:51 PM
ARB1977's Avatar
Damn that sucks...if you really want to know what kind of oil it is do an analysis.
Old Feb 23, 2007 | 02:06 PM
KyleT's Avatar
Send a sample to Amsoil to get an analysis done on it.
Old Feb 24, 2007 | 06:44 PM
partyman66's Avatar
You can tell by the smell for sure if it's gear oil or motor oil. Gear oil smells pretty distinctly pungent, whereas motor oil just has a flat oil smell(unless you're using German Castrol, then it will smell like hand soap kinda).
Old Feb 24, 2007 | 07:05 PM
86SR522REEFI's Avatar
yea, its pretty easy to tell if its gear oil or not, at work you can smell the gear oil from a bay or two away, motor oil isnt as strong.
Old Feb 24, 2007 | 07:12 PM
rezrunner92's Avatar
Exactly what i was thinking. You should be able to easily tell weight difference between 80 gear oil to 30 motor oil.
Old Feb 24, 2007 | 08:23 PM
4x4's Avatar
4x4
It's a Toyota. The transfer case would probably last a lifetime with olive oil in there.
Old Feb 24, 2007 | 08:32 PM
MudHippy's Avatar
I got a true life story, mine. I drove a VF1A chaindrive transfer case, with a 1/2 cup of water for lube, somewhere around 3500 miles. Not purposely, that's just how long it took to even make a sqeak loud enough to hear. Two new bearings, two seals and a good cleaning, GOOD AS NEW! I like the olive oil idea, don't even tell me that's based on a true story. Cause I'll probably believe it.
Old Feb 26, 2007 | 05:22 AM
it was motor oil. very thin compared to 75-90. very thin.. and yes it smelled like motor oil
bigjstang
Jun 2, 2025 03:56 PM
Sep 4, 2015 09:27 AM
Tykiller1994
Aug 10, 2015 07:49 PM
crashburnoveride
Jul 10, 2015 06:39 AM
toyoda8488
Jul 5, 2015 10:18 PM
