noisy belts and pulleys??
Old Feb 26, 2007 | 04:12 AM
mkgarrison5's Avatar
hey guys any of your trucks have noisy belts and/or pulleys? i dont have chirping noise. they are just noisy, esp when its cold or has been raining for hours. any tips or just live with it? from what i have seen the belts are in good condition
Old Feb 26, 2007 | 06:17 AM
YotaFun's Avatar
I am having a similar issue.
After I went on an off-raoding trip on the way home, one of the pulleys in the engine bay began to start making a noice.
I knew it wasn't the belt because I wasn't squeeling or loosing any power.
I believe it is in the altenator, because I notice that my bat light would turn on occasionally, gratned the bat light has been gone since but still I believe that is the bearing that is having the issue.
Old Feb 26, 2007 | 06:47 AM
gpcollen1's Avatar
How old are your belts? Have you checked the tension lately? Those are the two biggies with any vehicle.
Then on to the pulleys! I need to replace the AC tensioner pulley on mine. It just looks like the bearing is leaking a bit. It could be any of them if not the belts.
Old Feb 26, 2007 | 06:50 AM
86toysr5's Avatar
when my altenator went out if i listened while driving i could here it making a howling like sound
Old Feb 26, 2007 | 06:54 AM
the sound coming from the belt area is common. i hear them on other vehicles, nothing that really sticks out like loud chirping or metal rubbing and etc.... maybe theyjust need to be tightened.. how do i tighten them? its on a 3.4 v6 tacoma .2002... thanks guys
Old Feb 26, 2007 | 04:26 PM
jdsdj98's Avatar
I recently had to pull out my power steering tension pulley as it was getting noisy. I just cleaned it and shot some WD-40 at the bearings as a quick fix. It helped a little. I've been looking for some type of Teflon lube to get down in there but haven't made it too much of a priority. I wouldn't be too alarmed by it if your belts are properly tensioned and in good condition. Just try to nail down exactly which pulley might be the culprit, yank it, clean it, lube it, and stick it back in.
primordialbeast117
Dec 19, 2015 12:23 PM
moparbay
Oct 6, 2015 09:24 AM
Obmi
Oct 4, 2015 11:30 AM
dbollier123
Sep 29, 2015 05:23 PM
EVars
Sep 29, 2015 02:06 PM
