vibration issuses
Old Feb 26, 2007 | 11:16 AM
dibbz's Avatar
vibration issuses
i have got some steering wheel vibration at around 45-50 mph. higher speeds it's fine. this all happened after i changed my front rotors and brakes. got my tires balanced again (3000 miles after being mounted) and still vibration occurs. anything else i should check or have adjusted? i have a tacoma dbl cab prerunner. thanks
Old Mar 6, 2007 | 10:22 AM
dibbz's Avatar
anybody?
Old Mar 6, 2007 | 10:45 AM
GSGALLANT's Avatar
Check the runout on your rotors, approx 1 inch away from the edge to see if they are warped.
Ringmaster's Avatar
Rotors could be out of balance.
I would suppose remove them, have them checked on a brake lathe with a dial indicator. [ runout ]
Some rotors I have seen have weights driven down into the cooling fins to balance them.
Or, have the tires/wheels balanced on the rig, this way everything gets balanced.
Old Mar 6, 2007 | 03:08 PM
BajaRunner's Avatar
Could try replacing your steering rack bushings, but, really, 45-50mph range aint too bad.
Also, have you tried rotating the tires?
hiluxinargentina
Sep 30, 2015 05:51 PM
JPV
Sep 28, 2015 03:15 PM
Odin
Sep 26, 2015 06:56 PM
4Xtruck
16
Sep 24, 2015 09:38 AM
tinigunner11
Aug 14, 2015 01:19 PM
