gear oil question
Old Feb 25, 2007 | 08:00 PM
Alexander 26's Avatar
gear oil question
Hi guys!! i have a question. couple months ago i've changed gears on my truck. i went from 4.10 to 4.56. i've driven around 3000 miles since then. i already got the gear oil changed after first 500 miles....and yesterday decided to check it. it was realy dark. no metal pieces....just a fine metal dust. is it ok??? or should i go back to the shop to have them chek it again??
thank you!!
Old Feb 25, 2007 | 08:01 PM
oooo...by the way it's 2000 v6 4wheel drive
Old Feb 25, 2007 | 08:27 PM
anyone??
Old Feb 25, 2007 | 08:54 PM
Knuckles's Avatar
i dont see why it wouldnt be okay to change? IF they used synthetic gear oil to change it that may be why it appears dark.
Old Feb 25, 2007 | 09:02 PM
Elton's Avatar
i bet its not as dark as mine with 145k on it
Old Feb 25, 2007 | 09:04 PM
DeathCougar's Avatar
If you already changed it once, then leave it.
If you REALLY aren't feeling comfortable with the darkness, then change it again. A little peace of mind goes a long way, especially with Toyota.
Old Feb 27, 2007 | 02:02 PM
does this look ok???
Old Feb 27, 2007 | 02:33 PM
MudHippy's Avatar
Seen alotta gear oil in my day, looks good. That fine particulate may not even be entirely metal(the phosphorous coating also wears from the gears), and is perfectly normal. You can change the fluid as often as you can afford or definetely when the manufact. recommends.
Old Feb 27, 2007 | 02:36 PM
thank you!!! i was realy worrying about that!!
bigjstang
Jun 2, 2025 03:56 PM
smthwsn357
May 1, 2024 07:28 AM
mskalmus
May 28, 2017 07:51 AM
87blyota
Jul 10, 2015 04:31 AM
Jnkml
Jul 6, 2015 01:20 PM
