Squeal When I turn the wheel
Old Feb 24, 2007 | 01:49 PM
YM13's Avatar
The colder the engine is the louder the squealing noise is when I turn the wheel. Also the RPMs rise maybe like 500. I checked the steering fluid and it is at the right level. Could the pump be dying or is this a normal thing? Also does the steering fluid ever need to be drained or is it a "keep-filling" kind of thing....
Thanks in advance....
Old Feb 24, 2007 | 02:17 PM
MudHippy's Avatar
It should be flushed and replaced many times in a vehicles lifespan, many don't and just continue to add fluid, not a great idea. It sounds like a loose/worn belt to me. It's loose if you can move it more than 1/4"-1/2", then just retighten. If it's cracked or fraying apart, replace asap. The pump may need rebuilt/replaced, if not.
Old Feb 25, 2007 | 01:35 PM
4Legz's Avatar
the increase in rpm's is normal, sounds like a loose belt.
Old Feb 25, 2007 | 01:36 PM
DeathCougar's Avatar
Replace the belt. You should do that anyways if it ends up being the pump, so might as well try cheap and quick first.
Old Feb 26, 2007 | 05:20 AM
mkgarrison5's Avatar
mine squeals a little when the steering wheel is turned all the way to the left or right
Nailit69
Diesel Swaps
Jul 21, 2015 05:28 PM
PlayAwhile
Jul 20, 2015 11:36 AM
rushw
Jul 18, 2015 01:46 PM
Hamonacracker
Jul 17, 2015 08:33 AM
skoti89
Jul 6, 2015 07:45 PM
