98 tacoma help
Old May 18, 2016 | 07:24 PM
85toypickup's Avatar
98 tacoma help
Looking at buying a Tacoma and came across one. Its a 98 with the 2.7, the ad said the motor was rebuilt, but the check engine light comes on and off because of a vacuum leak. Could this be a major problem/what are the solutions? thanks
Old May 18, 2016 | 11:46 PM
wyoming9's Avatar
You might want to pull the codes and see just what your dealing with.
What part of the world does the truck live in does it see winter chemicals ??
If so what is the frame and the rest look like If your new to Tacoma`s you might not know of the frame issue
Old May 19, 2016 | 04:59 AM
Definitely no problem with rust here in the southwest. Also could a bad egr value cause the check engine light to come on and off due to vacuum leak?
Thanks
Old May 21, 2016 | 03:58 PM
tantacoma's Avatar
EGR valves rarely fail, but are routinely blamed and replaced without proper troubleshooting. It is only one of many components of an EGR system.
Get the code(s) read before blindly replacing stuff.
87runnerhawaii
Jun 8, 2016 12:02 PM
Toyotabc
Apr 16, 2016 07:24 PM
yotapwru
Washington
Apr 7, 2016 01:41 PM
nbl300
Mar 31, 2016 05:19 AM
calimazoo
Feb 27, 2016 03:30 AM
