Grease fitting/Zerk broke on LBJ
Old Apr 4, 2016 | 03:21 PM
dromomaniac's Avatar
Like the subject says. Most of the zerk's threaded section is inside the threaded port on the lower ball joint.
Any nifty tricks to retrieve this guy?
Old Apr 4, 2016 | 03:26 PM
millball's Avatar
They're usually not turned in too tight.
An easy-out will generally remove the butt easily.
No drilling , the hole for the easy-out is already there.
Where theres room, I've got them out using the tang of a small file.
Old Apr 4, 2016 | 03:32 PM
A file isnt a bad idea. I'll try it.
I'll have to go get a small easy-out, otherwise
Old Apr 4, 2016 | 03:41 PM
MAN! Thanks for the inspiration! I ended up using a pick. Since there was a jagged edge where it sheared off I was able to feel for it with the pick and turn it back until I coul use my fingers.
Brand new BJ,I was ready to pout.
Cheers!
Old Apr 4, 2016 | 03:55 PM
millball's Avatar
When you are looking for a replacement, don't forget that metric and American zirk threads are different.
Old Apr 4, 2016 | 04:01 PM
skeeter0288
Apr 1, 2016 02:01 PM
aamsowens
Mar 30, 2016 03:55 PM
burninggraphite
Mar 21, 2016 05:27 PM
Andy A
Mar 14, 2016 02:33 PM
Joshua White
Mar 11, 2016 08:07 AM
