Intermittent hard brake pedal after initial application - '00 4runner.
Old Apr 8, 2016 | 09:18 AM
94 Newbie's Avatar
I have a 2000 4runner that if you jam on the brakes, the first stop is ok, but if you let off the pedal and apply it immediately again in many cases you get the hard pedal.
The brakes have never felt awe inspiring since we test drove it, but they have never been in the " Oh, Sheeeeet" category, either.
I have had the passenger side real axle seal leak fixed about 2 years ago and now have an extended rear axle breather. They may not have changed the shoes, though, as I noticed oil on them yesterday when I was getting the tires rotated.
I cleaned them last night, and both drums feel warm after braking and I do not notice any pulling.
After a bunch of research I decided I would try a different booster.
Got a boneyard unit 1st thing this morning out of another '00 runner and there is basically no change.
Could one of the calipers be hanging ?
I read where I could pull the boots out a bit and spray WD40 on the pistons - I may give that a whirl.
I hate tossing parts and $'s at it , but felt the booster was cheap enough, and a reasonable enough possibility, that it was worth a shot.
Any thoughts are appreciated - thanks !
Britt
Old Apr 8, 2016 | 12:20 PM
vasinvictor's Avatar
Is there a check valve between the booster and the manifold on that year? Or is the check valve built into the booster?
Old Apr 8, 2016 | 12:33 PM
94 Newbie's Avatar
The check valve is on the booster.
Right now it is the boneyard one - I had changed it earlier with a new one with no change in the brakes.
Old Apr 9, 2016 | 10:36 AM
94 Newbie's Avatar
In case anybody needs the master cylinder to booster gasket P/N
P/N 47275-12020 at $ 1.82.
Not used yet as I have not been able to adjust the booster rod length on the original sitting in the garage and don't want to screw the one in the truck up experimenting ...
*sigh*
Wrenching is fun , huh ?
:p
Britt
Old Apr 11, 2016 | 04:52 AM
Malcolm99's Avatar
All my 4runners all have a hard pedal if you apply the brakes immediately after letting off, don't do that, do you have ABS, if so you should already no to never pump brakes. What is you idle, it should be 750, if it is 1000Rpm you will have hard brakes.
Old Apr 11, 2016 | 08:06 AM
94 Newbie's Avatar
It does have ABS, and hot idle in park with the a/c off is probably around 750 to 800 - around 650 in drive.
I am not pumping, but rather doing back to back stops.
I noticed the wife's 01 Ranger acts similarly , so maybe it is normal for ABS , but if so, I don't understand it.
Thanks !
Britt
theMonch
Nov 6, 2016 02:53 PM
mrroach2839
Apr 5, 2016 11:09 AM
Sahale15
Apr 1, 2016 08:54 PM
Brendan
Mar 23, 2016 12:01 AM
Amos Elam
Mar 21, 2016 03:07 PM
