Slight pause after turning key in ignition
Old Apr 3, 2016 | 07:49 AM
Up&Down's Avatar
So when I turn the key in the ignition to crank the truck up there is a slight pause before the starter engages and it cranks.
Is this an indicator of something to come?
Bad starter contacts perhaps?
Thanks.
Old Apr 4, 2016 | 11:36 AM
vasinvictor's Avatar
Prob just a corroded connection somewhere. Battery terminals, block to ground, starter terminal, or finally failing starter. Start checking wires.
Old Apr 4, 2016 | 12:22 PM
Marc's Avatar
Do you have an anti-theft immobilizer by any chance?
Mine do that sometimes.
Old Apr 7, 2016 | 03:31 PM
se7enine's Avatar
If the pause starts getting longer than I would bet it's the starter. Mine did this for a while. Mostly in the cold though and not daily.
Old Apr 7, 2016 | 03:36 PM
Up&Down's Avatar
So I cleaned up the ground on the battery and the one on the frame and cleaned up around the starter contacts. It's gone but it's only been a few days. I'll try to remember to post again in a month or so. If I don't, assume that fixed it.
Moving out west in three months. Grand plans for scoring a cap, doing the mini-header install, cleaning TB, and sorting out the P0441 (likely just replace the VSV).
Might be threading from Seattle next time.
Yotaboy79
Jul 2, 2016 07:27 AM
Up&Down
Apr 1, 2016 10:50 AM
MAINETOY
Mar 30, 2016 05:37 AM
westcoastkevin
Mar 29, 2016 11:15 PM
ariashemi
Mar 13, 2016 09:44 PM
