Help with testing fuel pressure
Old Aug 13, 2016 | 12:38 PM
tylermac's Avatar
Hey all, first time poster. I'm helping a friend with a 1999 4Runner, 3.4L 5VZFE engine. I rented the Autozone fuel pressure tester, I put the banjo bolt on the RH fuel rail, but the back of the timing cover does not allow enough room to connect the pressure gauge. LH rail has even less room. I've been scouring this site and others for guides, but I can't find anything. What am I doing wrong?
FWIW the car is running rough and has no power, and is throwing misfire and cat codes, and I'm trying to test the easy things one by one. Spark is good, compression is good enough, so I imagine he's either got fuel pressure issues or a plugged cat. Any help is greatly appreciated.
Old Aug 15, 2016 | 12:53 PM
wyoming9's Avatar
If you have not figured out move the timing cover front enough to get your gauge on
Secure it so it does not hit the rotating fan
Old Aug 15, 2016 | 01:02 PM
tylermac's Avatar
Thank you for the reply. The plastic cover isn't the problem, it is the rear metal fixed portion of the cover that is in the way.
Toyota sells a SST for this job and my buddy is picking one up.
99grnrunner
Apr 17, 2016 03:51 PM
128keaton
Feb 16, 2016 06:12 AM
bigbog
Jan 30, 2016 03:57 AM
pendrag
Jan 28, 2016 07:42 PM
PAVEYOTA
Jul 21, 2002 08:25 AM
