P0440 code + trouble filling gas
Old Mar 14, 2016 | 04:56 AM
lnlogauge's Avatar
I'm trying to knock down my CEL's before april, when I have to get emissions. The only code I have left is the P0440 code. I'm guessing it's related, but I had trouble the last time getting gas. The pump kept stopping everytime it started to flow. I'm guessing this is a bad gas valve. if it is, do you have a part number, and instructions on replacement?
car in question is a rust free, 2001 4runner (223k).
Old Mar 14, 2016 | 10:57 AM
vasinvictor's Avatar
What's a gas valve? You have a vent line that goes from the upper filler neck to the tank, and a dobber probably built a nest in that.
Old Mar 14, 2016 | 11:17 AM
lnlogauge's Avatar
vacuum switching valve.
Old Mar 14, 2016 | 11:21 AM
I think the two might be unrelated actually. Your gas vapors don't vent to your EVAP can while filling up, the vent line I described does. It sounds like it's at least partially clogged. It's pretty easy to pull off blow thru it. The PO440 is evap related, but could be something as simple as a bad seal on your gas cap, or you not tightening it down until it clicks.
racehoss
Sep 14, 2016 08:51 AM
mike88se
Jan 30, 2016 05:39 PM
dlewis
11
Jan 10, 2016 05:22 PM
nekchris
Dec 31, 2015 08:16 PM
