Overheating
Old Mar 22, 2016 | 09:58 AM
Vics4runner's Avatar
Overheating
I have an overheating problem. I have changed the radiator,water pump, checked the heater core for clog and changed fluid. I'm stuck on why I am still overheating?
Old Mar 22, 2016 | 12:32 PM
wyoming9's Avatar
Red face
Just how are you measuring the temperature ??
Auto or manual??
Is the AC condenser Full of dirt??
Just what is over heating ??We hope it is a Toyota be nice to know just what kind??
Old Mar 22, 2016 | 05:07 PM
ThorInc's Avatar
Properly burped?
Old Mar 23, 2016 | 04:26 AM
roadtrekker's Avatar
Other causes of overheating may be low coolant level, clogged coolant passages and improper air/fuel mixture or ignition timing.
Old Mar 23, 2016 | 05:16 AM
Malcolm99's Avatar
Could be the clutch for the Fan.
Old Mar 29, 2016 | 10:05 AM
rickkerny's Avatar
These engines are very vulnerable to overheating
Old May 14, 2016 | 10:13 PM
layifioren's Avatar
Not really
I have used over 6 3rd Gen 4runners over the years and I have never had any overheat. I think it comes down to the maintenance
Old May 15, 2016 | 10:06 AM
75w90mantraN's Avatar
T-stat changed? Coolant leaks? CEL? Broken fan clutches, heard that one too. Head gasket compromised? Too much overheating will lead to that...
But I second ^above. They are not prone to overheating. I had a leaking water pump and low coolant and I somehow made it towing a 3,000 lb car through some grades in WA, OR, and CA. I just made sure not to push it.
I had a recently overheated Honda but it was so quick when it happened. It turned out to be a heater intake hose that bursted. Old, swollen, with oil and deteriorated when I put degreaser on the rubber. My mistake.
jiggseob
Mar 23, 2016 04:20 AM
Jonny246
Mar 22, 2016 02:35 PM
Sporkinator
Mar 18, 2016 06:08 PM
808-3VZE
Mar 16, 2016 05:09 PM
