coil spring question
Old Jul 26, 2016 | 06:04 PM
adavis's Avatar
Hello, I am in the process of taking a lift off a 2000 4runner sr5 4x4, the previous owner put spacers and larger coil springs on it. It has aftermarket 16 inch rims and 265/70/r16 on it now. I am wondering if I can take the spacers off the front ,get new bilstein struts, and order a set for OEM coils for the rear part number 48231-35200 is what is coming up for my vehicle, and still be able to use the 16 inch rims and stock size tires. My dilemma is that I am not sure if the truck came stock with 16s or if they were put on during the lift, the calipers are SW13L so I am pretty sure someone would have had to put these on if it came stock with 15s. I’ve been reading up on the numerous spring options that came with these trucks, and that the sticker in the door jamb my not be accurate. So long story short my question is, will 16 inch rims on 265/70 tires fit under a 4runner that was bought stock with 15 inch rims. Or do I need to buy the SPRING, COIL, REAR LH; SPRING, COIL, REAR RH. W(265/70R16 TIRE) part number 4823135250 that claim are for 16 inch rims.
Any help is much appreciated
Thank You
Old Jul 27, 2016 | 07:19 AM
scottishb's Avatar
I think you will be fine. 265/70s are fine, but 265/75s start to rub. You are good to go as far as I am concerned.
AUJWE
7
Jul 11, 2002 09:46 AM
Hermes
7
Jul 8, 2002 03:45 PM
be_deviler
Jul 1, 2002 05:27 PM
