Need Line Identifying Help on 99
Old May 18, 2010 | 07:36 PM
coonhound130's Avatar
I have a 99 4Runner SR5 . There is 2 metal lines coming up on passenger/middle side of engine bay on the fire wall , had 2 rubber lines attacthed to them but now they are removed with bolts stuck in the ends . What would these go to ? Can get pics Wed if needed to clarify what I am talking about . Thanks
Old May 18, 2010 | 07:42 PM
It is circled in red ....
Old May 18, 2010 | 07:44 PM
vital22re's Avatar
totally a bro
rear heater hoses
Old May 19, 2010 | 03:14 AM
Thanks , now to figure out why they are un-hooked ..
Old May 19, 2010 | 03:36 AM
GN-1's Avatar
Heater coil was leeaking and the guy did not want to replace it. You will have to before winter if you want to have heat.
Old May 19, 2010 | 08:37 AM
TheDurk's Avatar
Well, If it's the rear, then it could be the tubes themselves (pretty common as they are exposed to salt as they run along the bottom of the truck) or the rear core or both. The rear heater was a factory option so a lot of people do just fine without it.
Old May 19, 2010 | 04:58 PM
My front heat still works just fine . The truck came from up north and had a lot os rust under neath from the salt . Makes sense now . Thanks alot
cr@ves4wheelin
3.4 Swaps
Aug 17, 2015 07:47 AM
DadsTruck
Aug 1, 2015 09:14 PM
pyramid
Jul 30, 2015 10:05 AM
rushw
Jul 18, 2015 01:46 PM
Fundy Rider
Jul 16, 2015 01:35 AM
