Need help with my hitch wires
Old 04-17-2010, 10:30 AM
98blacksr5's Avatar
My 98 4runner hitch lights are not working and the HAYNES manual doesn't tell me much on how or where to trace them. can anyone tell me where to start? thanks.
Old 04-17-2010, 04:43 PM
eric-the-red's Avatar
Check the trailer convertor, it should be behind the large plastic panel on the driver side of the cargo area. If there is power going into it and none coming out replace it.
Old 04-17-2010, 07:13 PM
98blacksr5's Avatar
thanks i'll check that out.
Old 04-17-2010, 10:32 PM
Ron Helmuth's Avatar
I learned all about this last year. Hopkins makes some inexpensive "black box" replacements and I recommend their LED 4 pin connector as you upgrade so at a glance at the hitch location you can see what functions are working and which are not. Search "trailer convertor" here or Google
okay from that other forum but it's on Yota Tech as well:
http://www.toyota-4runner.org/access...-pin-help.html
the hardest part of the whole process is all the trim removal of your interior to get to the black box. SO be sure before you tear it all apart that you visually check the wiring as it snakes up into the cargo area-could be as simple as a chafed wire coming out to the hitch.
Old 04-18-2010, 02:56 PM
98blacksr5's Avatar
Thanks eric-the-red I took the converter off and tested it and I was only getting power in but none out, so i will look into replacing it soon. Thank you Ron Helmuth i will take a look at those LED connectors.
Old 04-18-2010, 02:57 PM
glad to help sir
Old 04-18-2010, 07:00 PM
CYi5's Avatar
My stock trailer module died, so I replaced it with the plug-n-play hopkins one. Super easy, no splicing necessary, as it uses all the same plugs as factory. Model 43415. Not bad for $32.
http://www.amazon.com/Hopkins-43415-.../dp/B0002Q7ZLO
Old 05-12-2010, 08:42 PM
could be on the passenger side for a 98-it's definitely on the drivers side on 99s however-
did you get this solved 98blackSR5? just curious if you figured it all out. Took me some trial and error....
Old 05-12-2010, 09:32 PM
98blacksr5's Avatar
yeah i did thank you, I tested the black converter box and it was getting power in but not out so it was bad, I just don't have the money to fix it yet.
Old 10-08-2010, 05:05 AM
francr's Avatar
Does anyone know where the converter is on a 97 4Runner?
Old 10-08-2010, 05:46 AM
type in your VIN on a site like Toyota Parts Zone and let the diagrams show you which side it is on.
Old 10-08-2010, 08:48 AM
98blacksr5's Avatar
yeah it was the converter box, just didn't change it yet. Thanks.
Old 06-28-2011, 05:28 AM
Ritzy4Runner's Avatar
Having a similar issue, mine is a 98 and it was located in the passenger side rear corner near the tail light (Factory installed)
sanctfy
All Other Toyota Swaps
09-15-2015 02:52 PM
58rennur4
08-04-2015 08:49 AM
defrag4
07-31-2015 10:50 AM
Daneums
07-28-2015 11:57 AM
80Truck
07-24-2015 03:12 PM
Quick Reply: Need help with my hitch wires
