OME 883 Question
Old Apr 11, 2010 | 05:29 PM
trollcruiser's Avatar
OME 883 Question
Just wondering who is running these coils on the front and if they are running a top plate spacer as well? Finished product will have a custom tube bumper and 9k winch or bigger. Thanks.
Old Apr 11, 2010 | 07:28 PM
Yukon's Avatar
Me, no spacer.
Old Apr 11, 2010 | 07:40 PM
JWaldz's Avatar
Originally Posted by Yukon
Me, no spacer.
x2
The 883s have proven to have a better spring rate and handle more weight over time without sag vs the 882s. Just from what I have read. Miller might chime in, too.. He's had his 883s for around 2 years now. He was used as a tester before they were even put into production in the states. Must like them cus he still runs them
Old Apr 12, 2010 | 11:32 AM
How much lift are you guys getting with just the springs?
Old Apr 12, 2010 | 12:03 PM
Yukon's Avatar
With ARB, Full budbuilts, and 10k winch, it is almost level with the 891's in the back. When I take out the spacer (rollover cone) in the rear, it will be level.
Old Apr 12, 2010 | 02:22 PM
FogRunner's Avatar
I'm running 883's in the front and 891's in the back. I have an ARB in the front with a 9.5XP winch, and its level front and back and I see about 3" of lift.
Whats surprising about the 883/891s is the ride is really smooth. I thought it was going to ride like a log wagon but nope it rides really smooth WITH THE ARB and winch. I tried it without the bumper and it about shook my kidneys loose.
FOG
Old Apr 12, 2010 | 03:21 PM
brian2sun's Avatar
No spacer here either. I'm not sure how much lift I got over stock because I had Daystar spacers before, but I'd guess 2.75-3". I have an ARB and NO winch and it sits very level with my 891s. The big difference is once you add more wieght from a winch, skids, etc.. the 833s don't sag like the 882s. I can sit on my front end and it barely goes down, maybe <.5" at the most and I weigh 250 lbs. I got the 883s because I plan on adding more weight and I'm glad to read that Yukon is running a winch and skids and it still almost sits level with his 891s - That's the whole reason I went with 883s over 882s, so I wouldn't need the top spacer later.
I think the 883s would be too stiff w/o an ARB (or similar) bumper like Fog said, it'll be a kidney bustin ride! Mine ride good, but here's some advise: DON'T buy E-rated (10 ply) tires with 883s because that is stupid stiff. Go with D-rated (8 ply) with the 883s.
Old Apr 12, 2010 | 03:24 PM
brian2sun's Avatar
Wait - Yukon, your sig says 882s.. Were you talking about 882s or 883s?
Old Apr 12, 2010 | 05:03 PM
Yukon's Avatar
Whoops forgot to change it. I have 883's for sure.
To elaborate a little, I had the 882's with the skids bumper and winch, and it sagged so I upped to the 883's and it actually rides much better! I think Im going to go to 890's in the rear to make it ride a little better. The only time the 891's rode right was with 4 people in the car full of gear towing a trailer.
Old Apr 12, 2010 | 05:22 PM
brian2sun's Avatar
Nice. At 1st I was thinking about swapping out my 891s for 890s or LC coils, but I've gotten used to them now and since I carry a lot around with me, they are probably going to stay.
Old Apr 12, 2010 | 08:03 PM
So aside from Fog and Brian, what type of measurements are you seeing? I have read conflicting stories on the real height of 891's. I am looking to get around 3" overall when it is said and done.
Old Apr 13, 2010 | 05:05 AM
MarkAidan's Avatar
When I purchase my OME a few years ago I was told I would get around 2.5" of lift all around; however, I think I actually have close to 2.75" in the front and 3.25" in the rear. I have never measured them, but by the looks of the rake those are pretty close specs. I cannot remember the actual part numbers, but I know I have heavy duty fronts/rears. I also know I clear the 285-75's by a mile in the rear!
I'm going to post up some pics later today in the day... I have since installed some newer Tundra rims on brand new (Pep Boys) Definity Dakota M/T, painted all my cladding/bumpers a charcoal gray and removed the running boards.
Old Apr 13, 2010 | 06:41 AM
Mauzer's Avatar
I'm just throwin this out there cause I haven't heard any one talk about this but...what if you used the Eibach coils from Toytec? They're rated at 620# so they should be able to handle the weight and they are progressive so the ride should still be comfortable. I haven't personally used them, just giving you another option.
nvdesertrunner
May 11, 2020 08:18 PM
he's gone
7
Dec 3, 2019 07:08 AM
punks_is_4x4
Aug 21, 2015 01:35 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
4Runnin2000
Jul 29, 2015 06:09 PM
