98 4runner steal
Old Apr 16, 2010 | 05:05 AM
bretskie27's Avatar
Talking 98 4runner steal
Hey guys I posted a few weeks ago regarding my 1998 4runner that i purchased from my co worker for 400 dollars. post was under this section under "Is it worth it". After consulting with a mechanic friend i was told that what he thinks happened is that when they removed the bolt from the harmonic balancer and the crankshaft that they used a impact wrench instead of the right tool and it stripped the threads at the end of the crankshaft.
He lent me his scope with a camera and i looked at the threads after about 4 threads on the inside of the crankshaft they are perfect so it confirms his thoughts.. He said if the bolt is good just screw it back in. All in all i believe that I just got a 98 4 runner with no rust for the cost of a new waterpump which was the original issues to being with....98 4 runner for 400$...
What do you guys think of these water pumps?
http://cgi.ebay.com/ebaymotors/1998-...Q5fAccessories
//http://cgi.ebay.com/ebaymotors/96-04-Toyota-4Runner-Tundra-3-4-L-5VZFE-GMB-Water-Pump_W0QQcmdZViewItemQQhashZitem3a493601b2QQitemZ2 50336379314QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAcc essories
Should i stay away from ebay deals or would it be ok to buy? Should I replace the timing belt or keep the one it has if its good?
Thanks Guys
Old Apr 16, 2010 | 05:07 AM
bretskie27's Avatar
From what he said there is a special tool that is used with a protector sleave to protect the threads at the end of the shaft and they didnt use the sleave. he knows this bc he has done it himself... Does this sound legit
Old Apr 16, 2010 | 06:17 AM
Mauzer's Avatar
I'll be the first to say it cause lots of people will follow with the same suggestion...go with Toyota OEM always. And your second link is broken
Old Apr 16, 2010 | 06:40 AM
HazMat's Avatar
Yeah your WAAAAAAAAAAAAY ahead anyway so why not go with the best. OEM for sure.
Old Apr 16, 2010 | 07:20 AM
bretskie27's Avatar
good call guys thanks
Old Apr 16, 2010 | 07:33 AM
Kerby J's Avatar
but sometimes you can find the genuine OEM Toyota parts on ebay like i did i found the water pump, timing belt, all other drive belts, new tensioner and all the gaskets for like $130 shipped off of there
Old Apr 16, 2010 | 07:44 AM
dallison's Avatar
wow, what a buy, oem
Old Apr 16, 2010 | 08:01 AM
JWaldz's Avatar
it's not genuine unless it reads "Toyoda" hehe
Old Apr 17, 2010 | 11:10 PM
Ron Helmuth's Avatar
I'm still trying to comprehend that somebody let a 98 go for $400. What a deal. And for inexpensive OEM parts I use my buds at TRDPARTS4U.com
yes the 2nd link does not connect- it likely expired or whatever.
Old Apr 18, 2010 | 10:16 AM
Kerby J's Avatar
jwaldz all the boxes had toyota printed all over them haha
Old Apr 19, 2010 | 04:10 AM
bretskie27's Avatar
its legit...ill take pics when i get it outside...its in my garage torn apart fixing the timing belt and water pump..
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
kyletbert
Jul 17, 2015 11:39 AM
Poppie51
Jul 16, 2015 06:16 PM
