So I relocated my XRC 10 winch solenoid... (pics)
Old 04-20-2010, 05:19 PM
Yukon's Avatar
And this is what I came up with...
Removed solenoid from this box
It takes up maybe a small half of the box, and the box looks like it just shields it from dirt.
So After it was out I located it in the area behind the Toyota logo on the grill, which is hollow, and if you line the solenoid up right it fits right in, shielded from splashes, and able to have water drain away from it.
I didn't get any good pictures of this step, but here is a bad one of the finished product.
Here is the only part of the solenoid that isn't tucked into the hollow spot
you can barely see the small part right up and to hte left of the logo. You can also see the remote plug here.
finished product
Used to look like this
you can sort of see the box between the lights
And then a few bonus pictures
Yup still works
re graded the trail a little bit...
Criticism? Thoughts? Comments?
Old 04-20-2010, 05:22 PM
BigBluePile's Avatar
It looks like one of your lights is aimed up a little high...other than that...
Did you extend the wiring or use what was there?
Old 04-20-2010, 05:26 PM
Yukon's Avatar
I haven't re aimed them yet
And I used what was there, If they had been longer than maybe a foot and a half the box would have probably gone into the engine bay. I actually like it more where it is.
Old 04-20-2010, 05:52 PM
Either way, clever!
Old 04-20-2010, 06:34 PM
Gerdo's Avatar
Nice
The box also shields the power terminals from something shorting against them.
Being close to the radiator, does it get hot? Heat is bad for solenoids.
malteserunner
Early Land Cruisers (Build-Up Section)
89
02-09-2018 06:59 AM
DirtRoad93
08-23-2015 05:50 AM
priest16
15
08-06-2015 07:43 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: So I relocated my XRC 10 winch solenoid... (pics)
